997 GT2/GT3 Forum 2005-2012
James Bond GT3 Upgrade.....
Old 07-13-2019, 06:26 PM
DJN
DJN's Avatar
Default James Bond GT3 Upgrade.....
Say this with an "evil euro villain" accent: "Zat looks very stew-pid Mr Bond! You should not try to convert your GT3 into a boat!"
Well, I am doing my best here in the hot Nevada desert during the summer (too hot for the track)....So it's time to put the GT3 in the air and perform some surgery.
It is a rather ambitious project, but things need to be put right on my "new to me" 997.2 GT3. More photos to come....
- Five lug conversion with new 19" Forgeline GA3R wheels and RE-71R's
- Full KW Motorsport Coil-overs (Purchased from Rennlister: bmwtye....Thank you Sir!)
- New two piece rear control arms with Tarett monoball ends and solid thrust bushings
- New Rennline Rear Toe links and dog-bones
- New OEM Thrust arms for the front (Cup Car lower control arms already in place up front)
- New StopTech Front "Trophy" Brake kit (will upgrade the rear next year)
- Full undercarriage cleaning and plastic panel repairs
Lots to do!
Cheers
Doug N
Old 07-13-2019, 09:02 PM
VID997
VID997's Avatar
Ambitious indeed! Best of luck.
Old 07-13-2019, 09:59 PM
gt2-josh
gt2-josh's Avatar
Nice work! Please keep this thread going. We need more of these on this board. JBO
Old 07-14-2019, 10:08 AM
JS
JS's Avatar
Love the radio !
Old 07-15-2019, 12:48 AM
DJN
DJN's Avatar
Originally Posted by JustinS
Love the radio !
LOL! Ah yes....my old 80s double cassette radio.....I don't even know how it got into my new garage....it should have been tossed years ago.
It is interesting to note that it is not even plugged in (I guess I am subliminally sentimental!!!).
The actual soundtrack for my garage work comes from a mini BOSE system connected to an old iphone belting out rock from the 60s,70s,80s, and 90s.
Old 07-15-2019, 02:37 AM
gt2-josh
gt2-josh's Avatar
Same setup in my garage. And on the rare occasion I want to hear anything other than exhaust intake and mechanical symphony since I did radio delete in my car.
Old 07-15-2019, 12:12 PM
DJN
DJN's Avatar
Well, just like "TPC Tom" has demonstrated.....the only way to clean your undercarriage is lots of time and hard work.
Also, critrus cleaners, brushes (tooth, nail, and brass bristle), rubber gloves, and a disposable (recyclable) cardboard mat are your friends here.
This takes care of road grime, baked on brake dust, residual oil and grease, and brightens up the cast aluminum pieces. I figured this would be easy with everything apart, not so, because there is more to do!
Once done you can treat the cast aluminum with a light film of WD-40....spray on, gently wipe and work in.
The critrus cleaner works well with a brass brush on cast aluminum, and plastic brush on plastic parts. A spray bottle with water rinses of the loose grime and cleaner on to the cardboard mat surprisingly well.....no need to pressure wash and flood your garage.
I left the rear strut in place (as a plug) for cleaning the wheel well.....it is now in the used parts pile.
Happy scrubbing!
Doug N
Old 07-15-2019, 12:28 PM
bweSteve
bweSteve's Avatar
Received 1,040 Likes on 660 Posts
have any of you guys used a steam cleaner for suspension & motor cleaning?
Just prior to my guy installing the PPF film on my 7.2-3, his detailer guy used a steam cleaner to wisk away grim off my calipers. WoW that worked good. FAST & easy.
https://www.amazon.com/Mc-Cullough-Heavy-Duty-Steam-Cleaner/dp/B000K9S2VK/ref=sr_1_7?keywords=garage+steam+cleaner&qid=1563204230&s=gateway&sr=8-7 https://www.amazon.com/Mc-Cullough-Heavy-Duty-Steam-Cleaner/dp/B000K9S2VK/ref=sr_1_7?keywords=garage+steam+cleaner&qid=1563204230&s=gateway&sr=8-7
My wife also has a steam cleaner that I've seen her use in the house (she probably has it stashed somewhere cuz she knows that once I figure out I can use it on the cars,...). Gotta go find that & see if it has attachments.
=Steve
Old 07-15-2019, 02:47 PM
M Coop
M Coop's Avatar
Nice garage!
Old 07-15-2019, 05:29 PM
DJN
DJN's Avatar
https://www.amazon.com/Mc-Cullough-H...gateway&sr=8-7
=Steve
Give it a try Steve and let us know how it goes....
I've heard dry ice works too...but is very expensive.
Elbow power is free!
Old 07-15-2019, 05:43 PM
DJN
DJN's Avatar
Originally Posted by M Coop
Nice garage!
Thank you! The New Garage was last summer's project....now it is time to get some real work done.
Sure helps to have a full size lift!
Also, I measured the previous alignement settings before eveything was torn down.....needless to say the alignments specs will be changed significantly.
Old 07-15-2019, 10:45 PM
mooty
GT3 player par excellence
mooty's Avatar
Received 5,482 Likes on 2,269 Posts
James Bond.
so where is the missile launcher. I like that.
Old 07-15-2019, 11:03 PM
DJN
DJN's Avatar
Originally Posted by mooty
James Bond.
Oh Miss Mooty-penny. Of course, it is in the plan, along with a passenger ejector seat (so don't annoy me)!
Old 07-17-2019, 08:13 PM
DJN
DJN's Avatar
After a good run of undercarriage cleaning and organization, it was finally time to begin new component assembly and chassis reassembly.
Putting the new suspension links together is fun work,until you get to the little rubber booties.....after two successful installs by hand, I had a blister on my left index finger.....time for a new method.
I was also able to use a friend's 12 Ton press, to remove the CL hubs from the wheel carriers, and press in the new bearings and new 5 lug hubs.
Now, it is starting to look like a car again!
Darkstar1 (07-30-2019)
Old 07-21-2019, 12:17 AM
mooty
mooty's Avatar
I am used to be ejected, no worries
I do love your wooden bench top. maple?
Quick Reply: James Bond GT3 Upgrade.....
