996 Turbo Forum 1999-2005
Want to lower my '03 996 TT - Help
Old 06-24-2019, 12:01 AM
gpatti
gpatti's Avatar
Default Want to lower my '03 996 TT - Help
So do I just get H&R springs? Are there different options? Appreciate any input.
Old 06-24-2019, 10:34 AM
Carlo_Carrera
Carlo_Carrera's Avatar
Received 2,218 Likes on 1,429 Posts
https://rennlist.com/forums/996-turb...in-shocks.html
Old 06-24-2019, 10:45 AM
gpatti
gpatti's Avatar
Thanks, Carlo. I should have mentioned also, this is not for tracking. I have a different car for that. Just looking to lower it a bit.
Old 06-24-2019, 11:06 AM
Third-Reef
Third-Reef's Avatar
H&Rs will be a lot lower. About 1"+. Does not sound like a lot but you will scrape on everything. i had to shim mine back up to GT2 height to be everyday drivable. You will also want new shocks with the H&Rs, Bielstien B8s are the recommendation. If you don't mind the price go for the Ohlins. Hands down sounds like the best streetable setup.
Old 06-24-2019, 11:10 AM
Dock
Dock's Avatar
X73
Old 06-24-2019, 03:57 PM
2fcknfst
2fcknfst's Avatar
Received 3,837 Likes on 2,921 Posts
I used the Bilstein coil overs - they work very well.
Old 06-24-2019, 05:25 PM
derrunner
derrunner's Avatar
I went the H&R / Bilstein B8 route because I got a great deal on the set. Happy overall with proper alignment. I don't have scraping issues unless there are significant dips such entering or exiting some parking lots. I can tell if it's going to happen and go in at an angle.
If you can't do it yourself it's going to be pricey. I also wouldn't do lowering springs on stock shocks.
As Doc mentioned you can get X73 springs, which were a factory option. You'd still want to go with new Bilsteins if you went that route.
Also, you might want to replace other bits, like mounts, while you have things taken apart. Good time to inspect everything and see.
Old 06-24-2019, 06:55 PM
03EvoIII
03EvoIII's Avatar
OP - I'm going to be taking off my X73 springs pretty soon if you're interested. Pm me if so.
Scot
Old 06-24-2019, 09:31 PM
"02996ttx50
"02996ttx50's Avatar
i've been with the MO30's ( think "bilstein b8" for comparison ) and hr reds for a decade now ( replaced the dampers once ) and love the stance and feel/height. it is "low" and a bit below gt2 height by probably 20mm and gt2 height is ( iirc? ) about -40mm below US stock ride height. it's not the "optimal" "city driving setup" but i stay *mostly" in canyons where its perfect.
so absent, coilovers adjustability etc, i'd go with NEW h&r reds ( sports ) and not go with "used" unless you know they were "barely" used. lowering springs "lower" but also they have a tendency to "sag" as they age.
Old 06-24-2019, 11:24 PM
pirahna
pirahna's Avatar
Scot
Why are you removing the x73 springs? Are you replacing the whole suspension?
Old 06-24-2019, 11:43 PM
03EvoIII
03EvoIII's Avatar
Only reason is because I was thinking about going with a tad bit lower spring like the H&Rs. I considered selling the whole setup off and just go with some coilovers but unsure yet.
pirahna (06-26-2019)
Old 06-25-2019, 08:50 AM
g-50cab
g-50cab's Avatar
I have the Bilsteins - good alternative. Can ratchet them down at the track to stiffen them up - or dial em back to go compliant on the bumpy roads
Old 06-26-2019, 01:10 AM
pfbz
pfbz's Avatar
Received 2,717 Likes on 1,461 Posts
I'm running H&R Sport / Bilstein B8.
IMHO, perfect. Not too low, not too stiff, not too expensive, just the right gaps and stance, definite improvement in performance, The only tough part is B8's can go on back-order between production runs and become difficult to get.
For comparison, here is the same car with oem springs (and wheels): (ready for off-road!)
gpatti (06-26-2019)
Old 06-26-2019, 01:22 AM
pfbz
pfbz's Avatar
For comparison, here is a picture from last Friday.
The car in the foreground has X73 suspension, background is H&R/B8. Both running identical size Apex wheels and tires. Sorry the picture isn't a bit better... IMHO, H&R is the preferable gap/stance and preferable choice. But you know what they say about opinions...
Old 06-26-2019, 01:58 AM
Dock
Dock's Avatar
IMO, X73 has the best overall look and stance. Why? Anything lower highlights the gaps in front of and behind the wheel, and makes them look out of place relative to the gap above the wheel. IMO, X73 does the best job of balancing the space proportions of the wheel relative to the wheel well versus what you get with lower ride heights.
Quick Reply: Want to lower my '03 996 TT - Help
