996 Forum 1999-2005
removing washer dome from headlights
Old 06-17-2019, 11:14 PM
mrfeh
mrfeh's Avatar
Default removing washer dome from headlights
I'm gonna restore my headlights w/ the 3M kit that is often recommended. One thing that is not clear in existing threads - what is the best way to remove the chrome washer dome without breaking it?
Thanks.
Old 06-17-2019, 11:36 PM
Ahsai
Ahsai's Avatar
Remove the light from the car then pump air (use a bicycle pump) to extend the sprayer. Then use a small screwdriver to pry out the chrome cover.
Old 06-18-2019, 03:34 AM
ion_berkley
ion_berkley's Avatar
...or drive at about 80mph and activate the washers....which reminds me, must order some new ones.
peterp (08-28-2019)
Old 06-18-2019, 12:46 PM
Capt. Obvious
Capt. Obvious's Avatar
Received 1,418 Likes on 777 Posts
You can also gently grab the cover and lift the sprayer up, then grab the, uh, "shaft" to hold it in place while you remove the cover. It's a little awkward but pretty easy.
Old 06-18-2019, 12:54 PM
808Bill
808Bill's Avatar
Or, just mask them off with tape.
Old 06-18-2019, 12:56 PM
mrfeh
mrfeh's Avatar
Related question - I already have some plastic polish. Should I give that a shot before going down the route of the 3M kit?
Old 06-18-2019, 01:09 PM
808Bill
808Bill's Avatar
Test a small spot. You'll still need to seal it when done. The kit has everything needed including sanding/polishing disc.
Old 06-18-2019, 02:29 PM
Capt. Obvious
If your headlights are yellowed or hazy, it's likely already too late for plastic polish. That would be something you use as a final step after using the 3M kit.
Old 06-18-2019, 02:38 PM
Prelude Guy
Prelude Guy's Avatar
I did this and still broke the cover.
Mask it off. It's not worth breaking it. You can't just buy that piece.
Old 06-18-2019, 02:45 PM
mrfeh
mrfeh's Avatar
FWIW - I saw a post somewhere that said the individual covers can be purchased. I'm sure it's an after-market piece.
Old 06-18-2019, 02:52 PM
808Bill
808Bill's Avatar
$60.00 a piece!
Old 06-18-2019, 03:10 PM
911Syncro
911Syncro's Avatar
This is one good reason why I always have at least 2 pairs of hemostats in my tool collection. Should be very easy to reach in and clamp that shaft and keep the cover up.
Here is a set of 8 for only $12.99, but there are other choices on Amazon.
https://www.amazon.com/Ultimate-Hemostat-electronics-fishing-taxidermy/dp/B01MPZKOI2/ref=sxin_3_ac_d_rm?keywords=hemostat&pd_rd_i=B01MPZKOI2&pd_rd_r=e5ddaf97-2acf-44cf-b380-4803f42aa4bd&pd_rd_w=bqEhh&pd_rd_wg=O9ucW&pf_rd_p=0bc35c17-1e0d-4808-b361-20ab11b00973&pf_rd_r=QT7CD6R7446TEF9HAQ8A&qid=1560881322&s=gateway https://www.amazon.com/Ultimate-Hemostat-electronics-fishing-taxidermy/dp/B01MPZKOI2/ref=sxin_3_ac_d_rm?keywords=hemostat&pd_rd_i=B01MPZKOI2&pd_rd_r=e5ddaf97-2acf-44cf-b380-4803f42aa4bd&pd_rd_w=bqEhh&pd_rd_wg=O9ucW&pf_rd_p=0bc35c17-1e0d-4808-b361-20ab11b00973&pf_rd_r=QT7CD6R7446TEF9HAQ8A&qid=1560881322&s=gateway
Old 06-18-2019, 03:45 PM
808Bill
808Bill's Avatar
https://www.amazon.com/Ultimate-Hemo...1322&s=gateway
Won't these crush the plastic tube? I wouldn't trust it on 17 year old plastic...
Old 06-18-2019, 04:38 PM
Capt. Obvious
You can still buy them from Porsche. They're pricey though.
Part # is 996-628-144-00-M100 for the right side.
Old 06-18-2019, 04:59 PM
911Syncro
911Syncro's Avatar
That's a good point, I have never seen that plastic tube. But the clamping force applied to the object is variable, they are notched so they can be locked incrementally with increasing force. So perhaps the least force would not crush the tube.
Quick Reply: removing washer dome from headlights
