997 wouldn't start after leaving it sit for about a month
Old 05-23-2019, 07:58 PM
earranagu
earranagu's Avatar
Default 997 wouldn't start after leaving it sit for about a month
My 997 was parked unused for a month as I was out of station. When I tried to crank it up, it wouldn't start. I hear click click ...and all lamps in dashboard flashes. after this oil measure starts and count downs from 60 mins. Need help!!!
Old 05-23-2019, 08:02 PM
LexVan
LexVan's Avatar
Buy a new battery.
Old 05-23-2019, 08:04 PM
Phinhead34
Phinhead34's Avatar
Originally Posted by LexVan
Buy a new battery.
+1
Old 05-23-2019, 08:07 PM
LexVan
LexVan's Avatar
And use a quality battery maintainer whenever parked in the garage.
Old 05-23-2019, 08:20 PM
doclouie
doclouie's Avatar
That is just a dying or dead battery. Battery maintainer if being left for a couple weeks.
Old 05-23-2019, 08:29 PM
MexicoBlueTurboS
MexicoBlueTurboS's Avatar
This
Amazon Amazon
and this
Amazon Amazon
If I even think it might be a week or more I put in on the maintainer.
Also consider an AGM when replacing - I am looking forward to when my battery fails
https://www.pepboys.com/bosch-platin...d900a30a1c0e11
Old 05-23-2019, 08:30 PM
Iceter
Iceter's Avatar
Jump start it, then drive it foe a while, or hook it up to a battery tender. Not all discharged batteries are dead.
Old 05-23-2019, 08:41 PM
LexVan
LexVan's Avatar
True, but, a healthy battery should be able to start a car after 30 days of inactivity.
Old 05-23-2019, 08:46 PM
rap
rap's Avatar
How old is the battery?
Old 05-23-2019, 08:52 PM
MexicoBlueTurboS
In my experience a battery discharged below 10.5 volts never really behaves that well and can't be trusted.
Only a voltage reading before charging and a much better charge/charger might indicate if the battery can be saved and trusted.
https://www.lifewire.com/car-batteri...-to-die-534765
Old 05-23-2019, 08:55 PM
MexicoBlueTurboS
I'm not sure that's true for some 997s especially when the alarm system is activated.
All of this burns power and leaves the battery at risk after a week to 10 days
The alarm system monitors the following alarm contacts:
– Alarm contacts in doors, luggage compartment lid, engine compartment lid and headlights.
– Interior surveillance: Movement in the interior when the vehicle is locked, e.g. attempted theft after breaking a window.
– Inclination sensor country-specific equipment: inclination of the vehicle (e.g. when attempting to tow).
If one of these alarm contacts is interrupted, the alarm horn sounds for approx. 30 seconds and the emergency flasher flashes.
After 5 seconds of interruption, the alarm is triggered again. This cycle is repeated up to ten times.
Switching on
  • The alarm system is activated when the vehicle is locked.
Switching off
  • The alarm system is deactivated when the vehicle is unlocked.
Information
  • If you unlock the vehicle with the emergency key in the door lock, you must switch the ignition on (ignition lock position 1) within 10 seconds of opening the door in order to prevent the alarm system from being triggered.
Information
If button on the vehicle key is pressed and a door or the luggage compartment lid is not opened, the vehicle is locked again automatically after 30 seconds.
Switching off the alarm system if it is triggered
  • Unlock vehicle or
    switch on ignition.
Switching off interior surveillance and inclination sensor
If people or animals are remaining in the locked vehicle or the vehicle is being transported on, e.g. a train or ship, the interior surveillance system and inclination sensor must be switched off temporarily.
  • Inform any persons remaining in the vehicle that the alarm system will be triggered if the door is opened.
Using the vehicle key
  • Quickly press button on the vehicle key twice within 2 seconds.
    The emergency flasher flashes slowly once. The doors are locked, but can be opened from inside.
Old 05-23-2019, 09:14 PM
Balr14
Balr14's Avatar
You should lock your Porsche if it's going to be left for any period of time. After awhile, it will go into sleep mode and require the key be used to open the door. If you don't lock the car, all of the "nannies" stay on and will drain the battery in a much shorter time than you might think.
Old 05-23-2019, 10:14 PM
Iceter
Iceter's Avatar
In my many years of owning collector cars that sit for weeks or months, I have owned dozens of batteries that led long lives after being fully discharged a few times. I have never had a battery crap out after being fully discharged only one time.
Everyone is very eager to spend the OP’s money. His battery may very well be on its last legs. But, batteries are expensive. Replacing one after a single discharge without attempting to charge it and continue using it is both wasteful and stupid.
Old 05-24-2019, 01:33 PM
Fahrer
Fahrer's Avatar
My advice when it comes to new batteries is to find one that was manufactured within the last 6 months ( preferably within the last three months). They have stamps or stickers indicting the month. Before installing the battery, hook it up to a battery charger ( not a maintainer) and bring it to a full charge. After installation use a good battery maintainer if not using the car for some time ( a week or more).
Old 05-26-2019, 10:12 AM
Petza914
Petza914's Avatar
Received 6,166 Likes on 3,930 Posts
I leave all my cars on Battery Tenders when not being used. The last Optima battery in my 914 lasted 12 years. The Optima in my 997 is 7 years old now and the one in my wife's 997 is 6 years old. Keeping them topped up makes them last much longer than not.
Quick Reply: 997 wouldn't start after leaving it sit for about a month
