Jack points?
Jack points?
I checked the threads I could find but didn't find an answer. I am having my wheels Powder Coated and went to the place that is doing the job. When I walked in I saw that my car was setting on 4 conventional jack stands. In searching the forum I read that some people use a cross member in the rear to place their stands, but what about the front. I was going to ask that question when I was there but we started talking about other things (like when will it be ready) and I got side tracked. Is there a CM in the front also?
I don't believe I've ever seen anyone jack just the front up via anything other than a jack point.
I jack my car from the rear first and since the car is stiff, you can place the stand under the front with the rear jacked up. I then used a bottle jack to place under the rear cross member as close to the jacked side as possible and release my floor jack in order to place my second stand. Rinse and repeat for the other side. I use the Esco shorter jack stands but a lot of members use the Jack Point jack stands, which are very easy to use as you don't need two jacks but they are expensive and a bit lower than I would like. If you don't mind spending the extra money, they seem like a very good product. I know that one member jacks from the center of the cross member so that you can easily place your two rear jack stands but that scares me. I am not brave enough to place than much pressure on it.
Sorry for being off topic, but I can't help noticing you lost a big chunk from your rear tire?
Yes, I’ve abused my Pirelli‘s. New tires are on the car but I was honestly a little concerned about making it to the shop to get the tires changed. They were all torn up pretty badly.
Yes, the way you are jacking up the car from the side rear makes sense when placing front stands. That is how I jack up my Subaru and RX-7 as well.
And you might want to look under your car for evidence.
