1st Dyno run complete - analysis help
Old 04-10-2019, 02:11 PM
Marti
Marti's Avatar
Default 1st Dyno run complete - analysis help
I have completed my first dyno run with the 928 and was a bit surprised that the power registered this low, it certainly feels quick on the road. As least there is still plenty to come but why this low? 330hp / 290 lb/ft at the crank
I am noticing that the power is not dropping off at peak revs like other dyno print outs that I have seen, not sure if this points to cam timing - only thing coming to mind
S4 89
Standard capacity
Colins cams
928 motorsport merged headers
X pipe
Re mapped with ST and fairly happy with the mapping,
standard inlet manifold has been modified
Old 04-10-2019, 02:25 PM
Mark Anderson
The Parts Whisperer
Mark Anderson's Avatar
Did you do a baseline before you did the work?
Old 04-10-2019, 02:31 PM
Lizard928
Lizard928's Avatar
How did you set the camshafts? Have you done a compression test to see what the readings are bank to bank (done hot).
Are there any faults on the ignition monitoring tab? Does it show any retardation per cylinder in that tab?
A baseline of before you start is always good.
Also I cannot remember what valve springs did you use?
Most auto S4s put down between 260-270 whp which is where you are currently.
Old 04-10-2019, 02:57 PM
Mongo
Official Bay Area Patriot
Fuse 24 Assassin
Mongo's Avatar
Stock???
Old 04-10-2019, 03:43 PM
Marti
Marti's Avatar
How did you set the camshafts? Cams set as per your instructions and checked several times with a 32vr tool.
Have you done a compression test to see what the readings are bank to bank (done hot). I have done while cold and cylinders were very close to each other. I could perform a hot CR test also?
Are there any faults on the ignition monitoring tab No, all good
Does it show any retardation per cylinder in that tab? No, ST has been done on both maps, igniting is taking a good amount of advance before knocking occurs. During the run I got a one knock under full load around 3k revs but that was all
A baseline of before you start is always good. I wish I had a baseline before. This run is to be the baseline before I start testing the new inlet manifold.
Also I cannot remember what valve springs did you use? I am using the new springs you supplied
It actually feels a lot better than the standard car but a lot of extra go came from playing with the ST and it certainly feels a lot quicker than before.
The car does have a standard exhaust system, could that be holding it back?
Old 04-10-2019, 03:48 PM
Marti
Marti's Avatar
Does the shape of the power curve point to anything anyone has seen before, Greg, Colin et al
what I am pointing out is that often the curve plateaus by say 5.5 and starts to drop off by around 6.2k where as this is still climbing at 6.5
Old 04-10-2019, 03:59 PM
Marti
Marti's Avatar
I also posting up a further run below, this was the previous run to the final run above.
The difference between the two runs is actually I shifted the flappy opening from 3.4k revs to something like 3.8k revs on the final run after I saw the below effects of the flappy at 3.4k which was putting a hole in the power curve
I plan further dyno runs with a completely stock inlet manifold as a comparison between modified stock and standard stock. I am wondering why power is just climbing and not plateaued off
Old 04-10-2019, 04:16 PM
terry gt
terry gt's Avatar
stock exhaust ? that's where your loosing power . 32 RW HP with headers and a duel 2 1/2 exhaust . at 350+ I was loosing power with the injectors wide open . now with proper injectors , there is even more power . 290 was my base RWHP . 91 GT
Old 04-10-2019, 04:46 PM
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,072 Likes on 1,183 Posts
His post says headers & X-pipe.
Old 04-10-2019, 04:53 PM
76FJ55
76FJ55's Avatar
Not that I necessarily have any input on where there are gains to be made, but aren't most dyno runs accompanied by an AFR graph across the bottom?
Old 04-10-2019, 05:01 PM
Mongo
Fuse 24 Assassin
Mongo's Avatar
Random thought, could the diameter of the primaries on those headers be too small? I'm assuming a good set of headers for these cars use a 1 7/8" primary diameter, not 1 3/4".
Probably a question for both Marti and Colin, but for those cams, are you using stock injectors? Ideally, wouldn't a bigger injector benefit Colin's cams?
Old 04-10-2019, 05:27 PM
Marti
Marti's Avatar
I should have mentioned that the injectors are 30lb so no issues regarding fuel supply. When ST on the road I managed to get the AFR all about target. I am actually pretty happy with the mapping.
I forget the exact size of the header pipes but they are a good size and proven to increase power over stock.
Old 04-10-2019, 05:55 PM
Mongo
Fuse 24 Assassin
Mongo's Avatar
I know there are cases where dynos can read power differently, sometimes understating. Typically it's calibration, but most (okay likely ALL) of the time these guys with dynamometers know what they're doing. Next thought is power rating - is it SAE???
In the end, the engine dyno is the most accurate, not a wheel dyno that attempts to calculate power loss through the drivetrain and back into the crank number.
Old 04-10-2019, 06:03 PM
Speedtoys
Speedtoys's Avatar
Received 1,034 Likes on 623 Posts
Stock???
Ya, some solid ones even automatic in the mid 270s.
Old 04-10-2019, 06:06 PM
Speedtoys
Speedtoys's Avatar
If you have reached the end of the stock ones, yes. Otherwise it would make no difference.
AF chart with a dyno sheet is helpful in "How does this look" discussions.
Quick Reply: 1st Dyno run complete - analysis help
