996 Forum 1999-2005
Intermittent check engine
Old 03-24-2019, 01:23 PM
tom__w
tom__w's Avatar
Default Intermittent check engine
I just got the 2004 4S Cab with 71K miles 3 days ago. Working on some 'cosmetic' type stuff (leaks, brakes, etc) when I noticed today that on deceleration (after pushing it hard) the yellow triangle will flash. It goes away after 5-15 seconds.
I need to plug in my reader but in the meantime, is this indicative of anything in particular?
996 Newbie
Old 03-24-2019, 01:49 PM
Ahsai
Ahsai's Avatar
Yellow triangle sounds like abs/psm. What has been done to the brakes and tires?
Old 03-24-2019, 02:07 PM
tom__w
tom__w's Avatar
I've only had it 3 days. Nothing by me and little to no service records.
Old 03-24-2019, 07:01 PM
jhbrennan
jhbrennan's Avatar
Go to the page in your owner's manual that shows the instrument cluster and pictures of the warning lights (maybe around page 68) and tell us what warning light you saw.
Old 03-24-2019, 07:07 PM
tom__w
tom__w's Avatar
PSM Information light
Old 03-24-2019, 08:19 PM
808Bill
808Bill's Avatar
What size tires are you running?
Old 03-24-2019, 09:02 PM
jhbrennan
jhbrennan's Avatar
OK...so it's not a CEL that's good. PSM light can flicker on if the PSM sensors intervene in your handling - here's what's said in the manual:
The light indicates PSM intervention even
when PSM is switched off (brake regulation in
the event of one-sided wheel spin).
Old 03-24-2019, 09:05 PM
tom__w
tom__w's Avatar
I was worried it was the CEL. Thank goodness it isn't.
I'll get my tire sizes a bit later tonight.
Old 03-25-2019, 01:44 PM
tom__w
tom__w's Avatar
285 / 35 / ZR19 in the back
235 / 35 / R19 in the front
These are the ones it came with.
Old 03-26-2019, 11:37 AM
tom__w
tom__w's Avatar
Any comments on tire size?
Old 03-26-2019, 11:42 AM
Scott at Team Harco
Just a car guy
Scott at Team Harco's Avatar
Sure. They're big.
Old 03-26-2019, 11:51 AM
tom__w
tom__w's Avatar
Angry
Originally Posted by Scott at Team Harco
Sure. They're big.
LOL, yes they are. Kind of stunned when I had to remove them to clear the drain.
Are these correct for the car? My PSM keeps intervening.
Old 03-26-2019, 11:57 AM
Scott at Team Harco
Just a car guy
Good question. The two may be directly related.
Old 03-26-2019, 12:10 PM
De Jeeper
De Jeeper's Avatar
Received 3,268 Likes on 1,706 Posts
Go to one of the tire diameter calculators and see how close they r. Since u r a c4 they have to be pretty close, 1-2% i think? Im also pretty sure the psm works off the abs sensors so it reads excess spin and pulses the abs.
Your car probably had 18's origianlly but if the 19's fit and they r close in diameter it wont hurt the car.
Old 03-26-2019, 12:36 PM
808Bill
808Bill's Avatar
yup.
Quick Reply: Intermittent check engine
