Lower control arm bearing assembly
For SaleSteering/Suspension
Hi All,
I have 2 like new inner bearing assemblies for 2 piece LCA's. Bearings are very good.
These will fit 997 GT3/2 and others. Culd probably also use them on 996 cars, but these are ~15mm longer than the standard 996 part, so if you are looking for LOTS of camber, this is the way to go...
Replaced studs, SOLD
There are three pics and the two close ups are of the same inner. Seems that if one were to post close ups, they would include a close up of each inner, not just the better of the two.
Also, that lower doesn't look like just a lighting issue. The thread looks damaged. Maybe post up a pic of that thread in this post for full transparency.
Thanks for the comments. I will put some better / different pictures up. I will also replace the studs with some new ones.
Ray
Ray
