996 Turbo Forum 1999-2005
Wheel studs or factory wheel bolts
Old 03-18-2019, 04:39 PM
Ogr8frogy
Ogr8frogy's Avatar
Default Wheel studs or factory wheel bolts
So the question is what do you prefer wheel studs or the factory wheel bolts?
I went to studs on my c2 and it was nicer using them
but my turbo has the PCCB’s.
Is it wise to stay with the factory bolts or can I use the studs with my brakes.
I think it would be easier using the studs in the sense of not hitting the rotors trying to put the wheel on. I know to use the guide pins but I’ll looking to see if there is any draw back to doing so with the studs.
I have not found anything in a search either.
So all and any input would be appreciated
Old 03-18-2019, 04:44 PM
TrillyPop
TrillyPop's Avatar
I prefer studs on all my cars, no question. PCCB makes no difference.
Old 03-18-2019, 05:11 PM
Dock
Dock's Avatar
Factory wheel bolts.
Old 03-18-2019, 06:28 PM
03EvoIII
03EvoIII's Avatar
Just ordered the 45mm rennline studs/nuts conversion kit for mine. I prefer the studs over bolts.
Old 03-18-2019, 06:50 PM
Carlo_Carrera
Carlo_Carrera's Avatar
Received 2,228 Likes on 1,437 Posts
Studs.
Old 03-18-2019, 06:53 PM
s65e90
s65e90's Avatar
Studs > bolts
Old 03-18-2019, 06:58 PM
docwyte
docwyte's Avatar
Studs for sure
Old 03-18-2019, 07:30 PM
manimal
manimal's Avatar
+1 for studs
Old 03-18-2019, 07:51 PM
2fcknfst
2fcknfst's Avatar
Received 3,851 Likes on 2,933 Posts
Studs on the diesels, studs on the Acura, studs on the Pioneer, studs on the STi, bolts on the Benz, BMW and Porsche...
Something appears to be going on with ze Germans...
Old 03-18-2019, 08:02 PM
Ogr8frogy
Ogr8frogy's Avatar
Well thanks for the answers, it will be one doing it soon.
just wanted to make sure, it’s the smarter choice in my book also
Old 03-19-2019, 07:40 PM
ipman
ipman's Avatar
Not to start a debate, but what are the advantages of using studs over OEM lugs?
Old 03-19-2019, 07:43 PM
2fcknfst
2fcknfst's Avatar
I know that when you use studs versus torque to yield head bolts on a diesel, the clamping force is greater - which I suspect is similar here.
Someone with better math skills than me can probably explain it more concisely.
Old 03-19-2019, 09:44 PM
Ogr8frogy
Ogr8frogy's Avatar
I would also say it’s easier putting the rims on or taking them off being held by the studs.
Old 03-20-2019, 07:26 AM
RennKit-Dave
Basic Sponsor
RennKit-Dave's Avatar
Studs. Easier on/off.
Dave
Rennkit
djcooper@rennkit.com
http://rennkit.com/
  • Patented eRam Kit™ for 996/997 Turbo & Carrera GT wings
  • Cal*Cool™ - brake cooling 996/997 / Bluetooth Retrofit Kit™ for 1998-2011 cars / Wing Extenders™ 987 Cayman / 997 Turbo
  • AUTO-BLiP for MT / Function F1RST Shift ***** / Girodisc 2-piece rotors / OS Giken LSD / Phenix suspension / Zunsport grills / 997/987 switches/PCM ***** / Border Coilovers
Old 03-20-2019, 09:19 AM
jdexter
jdexter's Avatar
I just ordered some studs. Like everything, powdrhound has already posted on this with the porsche motorsport information. H&R 1454005 is the part number for what you want. They install with 32 ftlb of torque to the hub. Then get the steel lug nuts. They need 118 ft lb.
Quick Reply: Wheel studs or factory wheel bolts
