Front Axle Lift problem
6th Gear
Hi All,
Here is my first post, please bear with me if I said something wrong.
I just got a 2017 911 Turbo S last week, only has 5000 miles on it, It came with a lot of upgraded factory options, including the Front Axle Lift option. This is my first Porsche, super excited to have this and join this forum!
After only having a car for a few days, I noticed the FAL stopped working (was working earlier when I got the car). Whenever I activate it, dashboard shows car is being raised or lowered, but physically it is not moving (there is some hydraulic noise at the front part of the car). When I drive the car, dashboard also shows "Lift System Fault, Service required". So I brought to local dealer here yesterday and was told today that the hydraulic cylinder is leaking and needs to be replaced. It is covered under warranty, but I have to wait till next week to get my car back as they don't have the part in stock. Obviously, I was pretty upset, as I paid a lot for the car, just got it for a few days and already have a problem within a week (considering it is a relatively new car too)
Questions to Rennlister:
1) Should I be worried about this FAL problem? Anyone else with this problem and can share experience? Is this common problem? Is there more to this hydraulic leak (like something else as root cause)?
2) Is this going to affect anything else on the car?
3) Is there any way I can check history of the car maintenance/repair service? Wondering if previous owner had same issue before.
Glad to have this forum to help anxious new owner like me. So thank you!
Congrats and welcome. Any pics of the car? I don't have experience with porsche FAL system however I feel like the stock 991 TTS front is so high at baseline I can't imagine ever needing to lift it unless one was wanting to drive up a curb. I am guessing that once it is fixed all will be well. That is what warranties are for.
A week after I bought my car the HVAC fan went out. It was summer and hot. I was pissed and started second guessing my purchase. After it was fixed and I started driving and enjoying the car that is a distant memory. So just wait for it to get fixed then enjoy! Did they give you a loaner?
welcome and congrats…I previously owned 17TT…there was a service bulletin about leaking cylinder seals!!!! no problems since dealer fixed…no o
there. problems ….good luck
Congrats and that is why buying a pretty new CPO car is the way to go......hopefully it will all be sorted out now and trouble free motoring......i.e. I had it happen with my Cayenne with a radio speaker making a stage buzzing noise and once fixed no longer an issue..................
6th Gear
Thank you guys.
The car is not CPO, as I bought it from a private owner in Florida. I got PPI done in Florida and everything checked out. It is a 2017 with 5000 miles, so it still has good period of factory warranty. Hope it is all good. Will update how it goes.
Follow up question:
When it is transported from FL to TX, the transporter company uses a ratchet wheel straps on all 4 tires to secure the car on the transport. When the driver secure it on the track, I can see it is pulling down the car.
Please see pic below. Anyone knows if this method is safe for the car? Is this going to cause any alignment or suspension issue?
Thank you!
Follow up question:
Thank you!
This is one fine vehicle! I wouldn't be worried to much. My FALS is something I use daily and it hasn't had any issues. In fact, I haven't had any issues with anything so far. 2 years in, zero unexpected maintenance needed. By far the best new car I've bought. Especially compared to all my BMWs.... ^^
on my (early) 18 GT3 I had compressor failure and they fixed it in day, all good now.
I noticed it is an air system, it's go that woosh sound when you lower it.
On my 18 GT2 the sound is very different! For sure hydraulic system.
Did they change mid cycle??
OK, everything is fine. They repair will be easy, will likely last the life of the car, and the car cannot be easily harmed by straps on the wheels yanking it down. Everything is going to be just fine. These cars are highly reliable and extremely robust. Good job with the purchase.
Thank you guys.
Follow up question:
Thank you!
Follow up question:
Thank you!
6th Gear
Thank you everyone for your replies. I am glad to hear this is normal and I don't have to worry about the strap on the transport.
Update on the FAL problem - I got my car back from dealer, they found the hydraulic cylinder was leaking and had to be replaced. They also had to replaced struts, thankfully all covered under warranty. The wait for the repair was painful though
Happy Holidays you all!
Gdjsk (02-14-2024)
