Fun times with my first TB/WP job
Old 10-20-2018, 07:52 PM
Uncle_Rico
Uncle_Rico's Avatar
Default Fun times with my first TB/WP job
I’ve started the WP/TB on my newly acquired 85. See here: https://rennlist.com/forums/928-foru...-85-928-a.html
I’m several hours into it and I’ve run across several broken items and a potential roadblock.
First, when removing the coolant plug on the engine block, I noticed a small line had broken off from the exhaust manifold. What is this line?
Next thing i noticed is that is that when I unbolted the alternator, there was a brown wire hanging loose. What does this connect to?
Last but definitely not least, when I crawled under the car I noticed the lid to the clutch housing is gone?! So...I guess I’m roadblocked because I can’t insert the flywheel lock?
Old 10-20-2018, 08:15 PM
Landseer
Landseer's Avatar
The broken tube is a test port. Ignore it for now, not an issue. A ball bearing can be inserted later to block the hole.
That missing cover shouldn't be that hard to source.
Best to have flywheel lock in-place. There are ways to do it by jamming, say, a board in there, but they have risk
Old 10-20-2018, 09:04 PM
ammonman
ammonman's Avatar
And the wire should be connected to the oil level switch mounted in the oil pan where it protrudes beyond the front of the block. Call Roger Tyson @ 928sRUs for help locating a bell housing cover quickly so you can mount the flywheel lock. If no one in DFW has a spare to sell the 1/2 off sale at 928 International isn't that far off.
Old 10-21-2018, 06:08 AM
StratfordShark
StratfordShark's Avatar
+1 on the oil level switch.
The metal female connector should be tucked up inside rubber cover, which pops onto a lip around the pin on the oil pan cover when pushed onto pin. Your’s looks bent/twisted which may be why it’s not attached (I’m not sure if the level warning is a make or break to ground - did you have a permanent warning before starting the job, or could you have yanked the wire off?).
Not to worry though - I found a small butt type connector which crimps onto that wire after you cut off old connector, and is a perfect tight fit on the level switch pin.
Old 10-21-2018, 07:30 AM
StratfordShark
Here's a photo of the pin terminal on the oil pan, and one of the original connector within rubber cover on engine loom — you can see the rubber 'ears' which let you pull rubber cover over lip around pin on the oil pan.
Old 10-26-2018, 12:28 PM
Uncle_Rico
Uncle_Rico's Avatar
Thanks for the helpful responses. I found a lower bell housing cover and I'm waiting for it to be delivered. I'm planning on fixing some of the other items this weekend. More questions below:
So I should be able to just plug this connection and a ball bearing is the best way to do that?
A little confused on where this wire should connect. Should it connect on the inside or outside of the oil pan?
Thanks again!
Old 10-26-2018, 01:26 PM
soontobered84
soontobered84's Avatar
The original cap nut has a hole in it to allow for the tubing that originally terminates on top of the engine beside the air box. After you remove your remaining section of tubing, the easier way to seal it is with a ball bearing, which seals both the orifice and also the cap nut with the hole in it.
The connection is on the top front outside "ledge" of the oil pan more to the left side of the car
Answers in green.
Old 10-26-2018, 04:22 PM
WyattsRide
WyattsRide's Avatar
Originally Posted by soontobered84
Answers in green.
To add to the above answer about the ball bearing plug. That plug can be held in place with a wormgear hose clamp, covering over the plug and around the exhaust pipe. At least that's how my plugs are held there. Not the prettiest, but effective. I'll try and get a pic this weekend if it's still unclear.
Old 10-26-2018, 06:18 PM
Geza
Geza's Avatar
While you have the front of the engine disassembled for the TB, it's a good time to tighten the front bolts on the oil sump. Just a suggestion.
Quick Reply: Fun times with my first TB/WP job
