WTB: Porsche 997.1 GT3 RS - PCCB SET
Does anyone here has a complete set for sale:
-4 pccb brake discs
-4 yellow calipers
All for a 997.1 GT3 RS from 2008
If yes; please sent me a pm with price and pictures
Thanks
Bart
-4 pccb brake discs
-4 yellow calipers
Thanks
Bart
Might be your lucky day. I've been looking for a set for my 6 forever...
https://rennlist.com/forums/market/1102315
does your car have aftermarket calipers? If not, and you have the standard larger front calipers/standard rear you can just get them refinished in the OEM yellow.
Agent Orange
On the 997-1 steel front rotors are 350mm and PCCB are 380mm. Calipers are also different. On the 997-2 both steel and PCCB rotors are 380mm and the calipers are identical, except for color.
The 997.1 pccb uprights is also different.
So if i want to switch over to a complete pccb set
Following parts needs to be changed:
-4 calipers (yellow)
-4 keramik discs
-Pccb pads
The overrights for the 997.1 can stay ?
So I want to go from Steel 997.1 to pccb 997.1 (year 2007-2008)
Grts
-4 keramik discs
-Pccb pads
Grts
If your 997.1 came w/ steel brakes you will need:
Rear:
Painted yellow caliper or new caliper. size is same steel/pccb
ceramic disks
pads
Front:
uprights / wheel carrier
the larger caliper
different mounting bolts
ceramic disks
pads
possibly different brake hose/line
brake line hard line on the caliper from the hose
You can look at the PET / Catalog and see for I450 option.
Rear:
ceramic disks
pads
Front:
the larger caliper
ceramic disks
pads
Hi Spyerx
Thanks for the additional info
Also found this info at the web (where you can see the mounting of the pccd and calipers in detail):
https://www.elephantracing.com/tech-...sion-overview/
There a saw the difference on the uprights...
It's going to be a challenge to find all the items for this swap....
Hi Spyerx
