Durametric Issues and Over-rev Report Question
1. Durametric issue/question with GT4:
I own a Durametric Enthusiast cable which is not certified to work on a GT4 but it has worked in the past for me to reset service reminders and to run an over-rev report. A couple of months ago I tried to use it and updated the firmware, and now it does not work. I called Durametric and got "it is not certified to work on that vehicle" and "you can't roll back firmware" so I am SOL. I will likely just sell the cable because there is not outlook that it will ever work again...
Has anyone recently used a Durametric on a GT4 and found it to work?
2. Over-rev report question:
I recently had my GT4 serviced at an good Indy shop because I currently can't reset reminders. While it was there, I had them run a DME over-rev out of curiosity since I did a track event this year and I wanted to see if that changed the report at all. The report was all good (zero over-revs) but it was different than what I am used to. The report only had Range 1 and 2 not Ranges 1-6 like I have seen posted in numerous threads and like what my Durametric showed when I first had it working as shown in the image below from December 2016. The Indy told me that that is how they are output now (2 Ranges). I see on the Durametric sight that describes the reporting function, that only 2 Ranges are shown: http://www.durametric.com/usedporschebuyersguide.aspx It describes a simpler system with 2 ranges where essentially Range 1 is okay, and Range 2 is a problem.
So is Range 1 & 2 just the way Durametric now reports over-revs, or is model based, or just a new system all together? If I were to take my car to dealer and have them run a report on a PIWIS would it be listed as Range 1 & 2 or 1-6? This is all just my curiosity but I am hoping someone here is more knowledgeable on the subject.
My old example with Durametric from 2016:
I recently bought one, not sure which firmware, but it does give a range 1-6 report.
It didn't reset the oil reminders though, I'm going to try them again individually.
I will be watching this thread closely. If my durametric is not a good option for my GT4 I won’t plug it in as I may as well save the VIN use.
If I remember correctly, service resets are under: Instrument Cluster --> Commands.
When was the last time you used yours? If you can post your firmware version that would be helpful.
I am running version 6.5.2.0 and I can reset the service indicators on both the 2016 981 spyder and the 2017 macan S.
I have not tried 6.5.5.9 yet but may soon on another laptop before I overwrite my good one.
I have not plugged the cable in again yet to check the firmware but I checked the PC software and I currently have 6.5.5.5. That is the version that was locking up midway through the Short Test.
I do have some promising news however... You guys inspired me to reach out to Durametric again and support sent me a link to a newer version that has some chance of working. That software version is 6.5.5.11. It is still does not officially support 2016 cars but if they have fixed the Short Test bug then I have hope it will work as it did when I first purchased it. I will provide an update this weekend when I have time to test it...
I also have a problem where I can't test individual modules. That might actually be a cable hardware issue. Support offered to test my cable of it persists with the latest software. I hope to test it later today.
I have great news! The software version 5.5.5.11 works like a champ. I hooked it up to my GT4 and received a message to update the cable firmware. After the update, it worked well and and all of my previous problems are resolved. I was able to run a Short Test and it successfully completed. I checked the over-run status and it worked. It reports 6 ranges as discussed earlier. I still don't understand why my Indy gave me a report with only 2 ranges but in any case I had a perfectly clean report. I did not try resetting any service reminders but they all showed as available. I just don't have any to clear so I can't test it.
If anyone is having trouble with their Durametric or hesitant to use up a VIN, I would recommend the latest software 5.5.5.11 without hesitation at this point. It looks like the latest official release is still 5.5.5.9 on the support page. I can PM anyone the link to the "beta" software download if they want it. Or you can contact support directly...
Short Test:
Service Reset Window:
Over-run Report:
After my 2 track days I thought for sure I would at least have a Range 1 over-rev but it is completely clean. I revved to about 8k a few times (as indicated on the RPM gauge) holding gears before entering corners but I never hit the fuel cutoff at any time. I figured that would show as a Range 1 based on rev ranges for other vehicles but I guess the GT4 has higher limits. I am not complaining. Maybe I am just slow
Short Test:
Over-run Report:
6th Gear
Hi sonorus,
I found this thread as I had just purchased a Durametric Enthusiast version to primarily view the over-rev report on my 2015 Cayman GTS. I noticed that my report looked just like yours (No over-revs listed and the production number was blank). I contacted Durametric and they asked me to create a log of me accessing the CPU information on my car. I sent them the log and they let me know that while they can confirm that the Durametric system is communicating with my car, the car is not reporting any over-rev information, They asked if I had the ECU tuned or replaced, and I have not (stock as it came from the factory).
I will let you know what I hear back from Durametric.
Mike C.
Mike C.
