oil change differences
Old 09-19-2018, 11:24 AM
dgjks6
dgjks6's Avatar
Default oil change differences
So last oil change I put in 8 quarts and was low. Had to add a 9th
Yesterday added 8 quarts was over full
Both with timed 20 min drain interval
Old 09-19-2018, 11:34 AM
HenryPcar
HenryPcar's Avatar
So much for the state-of-the-art German over-engineerng syndrome. Just give us our dipstick back.
Old 09-19-2018, 05:28 PM
Bruce In Philly
Bruce In Philly's Avatar
Received 1,405 Likes on 852 Posts
Yup, same for me.... I just measure what I take out and put the same or a bit less in. Seems to take a few readings to "stabilize: whatever that is.
Peace
Bruce in Philly
Old 09-19-2018, 11:40 PM
workhurts
workhurts's Avatar
9 quarts in what engine?
Old 09-20-2018, 08:21 AM
Petza914
Petza914's Avatar
Received 6,125 Likes on 3,901 Posts
I understand the 20 minute interval was the same, but that's not really long enough - needs an hour. Are you draining warm or cold?
Old 09-20-2018, 10:25 AM
dgjks6
dgjks6's Avatar
This time let the car idle a few minutes. Last time no idea. Could have been up to temp or maybe just let idle or somewhere in between
Interesting fact. I just got another 997.2 repair manual. This one has 14,000 pages. It describes how to do an oil change but does not give a drain interval.
And it says the oil capacity of the engine in 10L
So at best we are only removing 75-80%
Old 09-20-2018, 10:38 AM
96Tiger
96Tiger's Avatar
Attachment 1291660
Where did you get that repair manual?? I was going to get the pdf from eBay but it’s no longer available.
Old 09-20-2018, 12:35 PM
997v2cabrio
997v2cabrio's Avatar
On my 997.2 I fill to 7.5 quarts after draining warm for at least 1 hour, and then check it to see where its at. I usually only need to add a couple of ounces to show 1 bar off the top.
Old 09-20-2018, 02:34 PM
workhurts
workhurts's Avatar
7.5qts every time. Not sure how you get 9 qts back in.
Old 09-20-2018, 11:02 PM
Wayne Smith
Wayne Smith's Avatar
Received 1,139 Likes on 724 Posts
7.5 out, 7.5 back in. 997.2 with 16 oil changes that I've done over the last four years and 82K mikes.
Measure oil level before draining. Measure the drained amount. Figure what you want to add. Better to be a bar (or two) low than too high.
Old 09-20-2018, 11:22 PM
dgjks6
dgjks6's Avatar
Never burned a drop of oil? I'm at a quarts every 3,000 or so miles
Old 09-20-2018, 11:42 PM
workhurts
workhurts's Avatar
Any chance you miscounted or miscalculated the 1st oil change? Especially at a 20 min drain, I just don't see anything over 8 remotely possible.
Old 09-21-2018, 12:26 AM
Wayne Smith
Acquired stewardship at 35K miles. 117K four years later. 2010 C4S PDK.
In equals out within measuring capability. I use old empty 5 quart jugs to measure oil out (and recycle).
Drive times are enough to burn off moisture.
So practically speaking, never burned a drop.
The 9A1 varies, but others on this Forum have had similar experience.
Old 09-21-2018, 02:34 AM
dgjks6
dgjks6's Avatar
Off topic but since its my thread I'm going there. 20K+ miles per year - what tires do you run? Do you do 2 sets of rears and 1 set of fronts every 20K? I'm asking because I do similar mileage and switched to all season tires on my 996 because I was getting sick of spending that much on tires and kept will all seasons from my 997.
Old 09-21-2018, 09:11 AM
NuttyProfessor
NuttyProfessor's Avatar
Wow, these cars can hold 17 quarts of oil? I'm pretty positive that's overfilled.
Quick Reply: oil change differences
