Sponsored by: APR
Friend looking at a gt4
Old 08-20-2018, 04:47 PM
Ddesimone17
Ddesimone17's Avatar
Default Friend looking at a gt4
So I have buddy looking at a gt4 it’s set up for the track and has roughly $50k in upgrades ie suspension , 2 sets of track wheels, cage harness and RS carbon fiber front quarter panels
It’s priced right $95 k w 13,000 miles
The rub is the dme report would you consider buying it or pass ?
Old 08-20-2018, 04:49 PM
MileHigh911
MileHigh911's Avatar
PASS. Range 5 money shift. No Thanks And track mods typically decrease value of a car for resale
Old 08-20-2018, 04:50 PM
Ddesimone17
Do I understand this correctly , When you read the the over rev report range 4 over means 358 revolutions happened in the 311th hour which is really one quick shift ?
Old 08-20-2018, 05:13 PM
cox1974
cox1974's Avatar
Omg... No good gt4... Stay away from it
Every over Rev readings over level 2 is not a good thing... Level 4 and 5 are a really bad thing...
Old 08-20-2018, 05:19 PM
Jim137a
Jim137a's Avatar
I’m not an expert here but can someone explain to me how you can have more range 4 over revs than range 3.
Report shows 358 over revs in range 4 and only 69 in range 3.
My logic is that you would hit range 3 prior to hitting range 4 so range 3 number should be higher or possibly equal to range 4.
Or or is my logic completely screwed up and I reading the report wrong.
Old 08-20-2018, 05:22 PM
johnny2five
johnny2five's Avatar
I believe it only counts the max rev you hit each time.
LexVan
LexVan's Avatar
Good point. This just shows that the report is either totally bogus, or the DME was tampered with. Or both.
Old 08-20-2018, 05:27 PM
d00d
d00d's Avatar
GT4 over rev ranges;
1: 7800 - 8000
2: 8000 - 8200
3: 8200 - 8400
4: 8400 - 8600
5: 8600 - 8800
6: 8800 - 9000 or more
Bouncing off the rev limiter (not shifting up before red line) doesn't increment with the SDI9 ECU in the GT4.
Porsche reportedly refuses warranty claims for any range 3 and above, unless it’s been 50 (1), 100 (2) or 200 hours (3) since, not sure what number is accurate.
It cumulatively records revs in each range, but can only record one date, which is when the last one occurred.
1: https://rennlist.com/forums/991-gt3-...l#post15232996
2: https://rennlist.com/forums/porsche-...l#post15230929
3: http://www.911virgin.com/porsche/rev-range-information/
Old 08-20-2018, 05:45 PM
d00d
d00d's Avatar
It would make sense that the person missed a downshift, which sent the engine through the ranges just touching 5, further engine braking moved it into 4 where it lingered before the clutch was depressed and revs quickly dropped below 1.
Jim137a
Jim137a's Avatar
Reminds me of this thread we recently saw:
https://rennlist.com/forums/991/1086...uestion-2.html
Old 08-20-2018, 05:47 PM
Archimedes
Archimedes's Avatar
Received 3,857 Likes on 1,901 Posts
Wow, that's the worst DME report I've ever seen. I'd tell your friend to pass.
Old 08-20-2018, 05:50 PM
Dr.Bill
Dr.Bill's Avatar
The range 5 ignitions were only 20 hours ago. Range 4 ignitions & higher are generally bad.
I'd pass. There are lots of GT4's for sale right now. Probably will be more when the new one arrives.
Old 08-20-2018, 05:55 PM
FRIZ
FRIZ's Avatar
How about this one ...zero over revs ..
https://www.dallasmotorsports.com/20...59?photos=true
I know ..it was mine
Old 08-20-2018, 05:56 PM
GTS_Ninja
GTS_Ninja's Avatar
Originally Posted by d00d
Normal bouncing off the rev limiter is range 1, maybe also 2.
Porsche reportedly refuses warranty claims for any range 3 and above.
It cumulatively records revs in each range, but can only record one date, which is when the last one occured.
1: 7800 - 8000
2: 8000 - 8200
3: 8200 - 8400
4: 8400 - 8600
5: 8600 - 8800
Is your info confirmed?
I think this is a great topic of discussion, as much of the info out there is unconfirmed.
I once pinned the limiter for a brief sec (literally was a few tenths of a sec) on my old 991, and was worried about the DME. I then called my shop (a very reputable Porsche race builder I wish to keep unnamed) and asked if I had to worry about anything (overrevs on my DME). I was told, overrevs are only accumulated from downshifting into post rev limiter ranges, ie downshifting while high in rev range, into a pinned rev limit situation.
Another anecdote I will share is with a friend who is a tech in Porsche Service, who used to own a 981S. He is an extremely meticulous tech and car owner, who also pinned the car once or twice and in a paranoid state ran a DME Report (for free, must be nice) and the DME didn't record any overrevs each time.
Lastly, on the 981/991 if you pin the car, the ecu cuts fuel. So I am not sure if this instance records an overrev, I do not believe it does as that is what the fuel cut is for. Finally, the car mentioned above was clearly a track car. Probably by a driver who tracked it with autoblip off and this is most likely what led to the extensive overrev counts.
Lots of conflicting info out there. It would be great if a BGB, SST, HRD, GMG, RS1, or even a dealer could shed some light on the matter and put the myths to rest. For now, I am always careful but I do trust my sources, and believe that pinning will not show on a DME.
LexVan
LexVan's Avatar
Other than having bogus numbers (ie- 4s being higher than 3s), that's not really a bad reprt at all. Hypothetically, if there were about +50 hours on the DME since the last Range 5 event, the car would most likely be just fine.
Quick Reply: Friend looking at a gt4
