996 Forum 1999-2005
Question for Electrical Guru's
Old 08-17-2018, 04:47 PM
RBC
RBC's Avatar
Default Question for Electrical Guru's
Electrical is far from being my strong suit, and I have an odd situation that I can't figure out.
My gauge cluster went funky, and the usual troubleshooting did nothing to help. The battery and charging circuit test perfectly. I even replaced the ignition switch, given that they're known to fail. Anyway, I was wondering if anyone has seen this before:
1. I'm only getting 11.7 volts at the B1 fuse location, and 12.7 volts at other fuse locations
2. I get 11.7 volts with the key in the accessory position
3. I get 7.5 volts with the key in the ignition position
This is with the gauge cluster removed so I could rule it out as being the issue. Is there anything in the circuit that could cause this scenario at this particular fuse location?
Old 08-17-2018, 05:18 PM
Ahsai
Ahsai's Avatar
Can you re-do these tests on fuses B1, B2, B3 and B4 (with the fuses in place, undisturbed) since they all get power from the same wire from the current distributor under the dash right side (always hot).
Also take measurements on both ends of each fuse.
Old 08-17-2018, 05:36 PM
RBC
RBC's Avatar
Ok, here we go:
Ignition off:
B1 11.56V
B2 11.49V
B3 Not getting a measurement, numbers on my meter are jumping all over the place
B4 Same as B3
Ignition On:
B1 7.76V
B2 11.44V
B3 Same as B3 above
B4 Same as B4 above
Fuses all check out at 0.
Thanks for the help, very much appreciated!!!!
Old 08-17-2018, 08:04 PM
Ahsai
Ahsai's Avatar
Any water damage to the fuse box? Per the wiring diagram, all those 4 fuses get power from two 4mm^2 wires (Red/Black) that are connected to the power distributor.
You may want to check the back of the fuse box for those two wires.
Old 08-18-2018, 09:20 AM
RBC
RBC's Avatar
No water damage, the car has never been in the rain.
I'll check the back of the box today. I see there's also a relay in the circuit. Which relay is that, and could it be the culprit?
Old 08-18-2018, 09:34 AM
dcdrechsel
dcdrechsel's Avatar
Were the voltage readings the same on each end of the fuses ?
Old 08-18-2018, 09:38 AM
dcdrechsel
dcdrechsel's Avatar
OOPs I guess that was your last set of tests
Old 08-18-2018, 12:30 PM
Ahsai
Ahsai's Avatar
Great question and I also asked for those in my 1st reply. The OP has not provided that. His last set of test was with the ignition ON.
Old 08-18-2018, 12:31 PM
Ahsai
Ahsai's Avatar
I don't see a relay on that circuit. The fuses are basically wired to the B+ via the power distribution panel.
What year and model is your 996? US or RoW?
Old 08-18-2018, 07:05 PM
RBC
RBC's Avatar
Here are the readings with the ignition off:
B1 11.56V
B2 11.49V
B4 Same as B3
Could the issue be at the power distributor? I'm baffled by my inability to read voltage at B3 and B4. If I pulled the fuses from all 4 locations, shouldn't I get the same voltage reading across all 4?
Thanks!
Old 08-18-2018, 07:23 PM
RBC
RBC's Avatar
1998 base US spec.
Old 08-18-2018, 07:45 PM
Ahsai
Ahsai's Avatar
B1 11.56V
B2 11.49V
B4 Same as B3
Thanks!
I agree. I'm baffled too. Need to think about it more.
Old 08-18-2018, 08:51 PM
dcdrechsel
dcdrechsel's Avatar
Next logical step is to inspect backside of fuse panel and start tracing voltages all from the battery side .It would seem there is a connection issue with the bus
Old 08-19-2018, 09:26 AM
RBC
RBC's Avatar
Thanks guys! I'm not good at electrical, and those Porsche wiring diagrams look like hieroglyphics to me.
I assume I can trace the positive battery lead to something, and go from there. Does all the electrical route through the Power Distributor? If so, I assume I can start there and work towards the fuse box?
My first order of business is to remove the fuse box and inspect the back of it to make sure everything is sorted there.
Really appreciate the help.
Old 08-19-2018, 09:47 AM
dcdrechsel
dcdrechsel's Avatar
Since of the 4 fuses are getting power from the same source -pretty good chance problem is at the fuse panel
Quick Reply: Question for Electrical Guru's
