991.1 Sport Design wheel on 997.2
Old 07-20-2018, 06:47 PM
Syntax
8th Gear
Syntax's Avatar
Default 991.1 Sport Design wheel on 997.2
Hi all,
Purchased my first Porsche! Dead pleased. 997.2 c2s, 2009, good set of options.
It came with the 997.1 triangular wheel (and I assume 997.1 steering wheel control module), which many of the early 997.2’s did afaik,
Ive managed to get a good deal on a 991.1 Sport Design wheel and airbag, but I’m not sure what to expect for fitting this.
The car is manual, it has the multifunction stalk and multifunction controls on the steering wheel (which aren’t great) - the new sport design wheel ISNT multifunction.
Now, I suspect I’ll have to replace the control module with a 997.2 or 991.1 module to get the airbag and horn to work... but I’m not sure and can’t find any good info. Also expect there will be some coding required!
Hopefilly someone with more knowledge can help point me in the right direction.
Thanks!
Edit: here’s what I’ve learned so far
1. Upgrading from a manual, multifunction wheel (997.1+) is plug and play
2. Any manual, non multi-function, non heated wheel up to the 991.2 wheel will work
3. No new steering module or coding will be required
4. A steering wheel swap guide is available here
Old 07-20-2018, 07:47 PM
amplitude
amplitude's Avatar
The steering wheel fits right onto the splines and the airbag plugs right in. The multifunction stuff I'm not so clear on, however.
Old 07-20-2018, 08:33 PM
Syntax
8th Gear
Syntax's Avatar
thanks! I think the airbag connection differs between the 997.1 and 997.2/991.1 which required a module update?
Old 07-20-2018, 08:44 PM
amplitude
amplitude's Avatar
I have a sport steering wheel from a 991.1 in my 2009 C2 PDK; it was plug and play, though I lost the heated function. Easy install; 20 min start to finish. The only thing I had to go out of my way to get was a Torx T55.
Old 07-20-2018, 08:56 PM
Syntax
8th Gear
Syntax's Avatar
awesome, thanks! Did you have the 997.1 or 997.2 wheel originally? Was it non MF before?
edit: damn those black dials look amazing
Old 07-20-2018, 09:09 PM
amplitude
amplitude's Avatar
As my car is PDK, it came with the (then) newer 997.2 steering wheel. I did not have the multifunction wheel, however.
Install was a breeze; very simple and straight forward.
MarkTro (11-30-2023)
Old 07-20-2018, 09:29 PM
Syntax
8th Gear
Syntax's Avatar
Looks great, absolutely my goal. I think you may have a different steering module to me (997.2 vs 997.1) so I may need to change mine... sounds like the 997.2 module works fine for the 991.1 wheel though, so narrows it down thanks!
edit: anyone gone from the 997.1 style wheel to higher in a 997.2? Did the module need replacing?
Old 07-20-2018, 11:38 PM
alex911s
Man of Many Porsches
alex911s's Avatar
beautiful car .. congrats!! yes i replaced my 09 with sport design as well found a good deal here alcantara
Old 07-20-2018, 11:59 PM
Jimmylim
3rd Gear
Jimmylim's Avatar
Looks great bro. May i know where can i get this. i have a 997.2 and looking forward to have the same mod.
Old 07-21-2018, 01:06 AM
amplitude
amplitude's Avatar
It's a factory option, though it's easy to retrofit. You can try the sales forum here on Rennlist; Suncoast and other sites may have it as well. There was a very large backorder on these steering wheels a few months back and subsequently some colors are now out of production as well (as per Suncoast).
Old 07-21-2018, 01:51 AM
sandwedge
sandwedge's Avatar
Received 1,006 Likes on 714 Posts
Three options I'm aware of. I'm sure there are others.
1. Suncoast parts, factory wheel: https://www.suncoastparts.com/product/PDKPADDLE.html
2. Dallas Custom Steering Wheel: http://www.dallassteeringwheel.com/sw1.htm
3. DCT Motorsports: http://dctms.com/blogmain/2011/10/11...eel-st020j020/
Both Dallas and DCT will build a wheel to your specs where you can specify thickness, stitching, color and material. Cost varies but depends mostly on whether or not you have a core exchange. They build all wheels on stock Porsche wheels. I've bought two wheels from Dallas and it's one of the great overlooked mods out there. It's right there in your hands and in your face every moment you're in the car so I would do it again.
Old 07-21-2018, 01:58 AM
bhvrdr
bhvrdr's Avatar
Just did this...
Straight up swap. Plug and play. 20 min deal
Mike
frederickcook87 (08-29-2021)
Old 07-21-2018, 03:10 AM
Dripola
Dripola's Avatar
Originally Posted by Syntax
Hi all,
Thanks!
I did mine last week. I have a manual 997.1. I replaced my control module with part number
99761329703. My horn and airbag work. You may have the right module already installed but you will have to dig into the column
to find out. There is a guy in China who is the guru on this his site GPS Adaptor has most of what you need. A lot of people reference the different module number I believe it’s because they’re mostly tiptronic cars.
best of luck, it’s a great mod.
Old 07-21-2018, 07:04 AM
Syntax
8th Gear
Syntax's Avatar
Thanks, I suspect I will have to upgrade the module too. Seems the 997.2 module will work fine for the 991.1 wheel. Do you have a link to the site you mentioned?
Old 07-21-2018, 08:43 AM
Dripola
Dripola's Avatar
The used module I bought was from a 2009 car so you may be ok. Website is gpsadaptor.us. Go to the blog section you can find a link to how to change the module. I actually installed a 2017 tiptronic cayenne wheel. Removed the paddles and multifunction as it was so hard to find a good deal on a manual wheel. Given you already have steering controls activated his module may be of interest.
Quick Reply: 991.1 Sport Design wheel on 997.2
