is your oil line touching the header ? or is it just the pic ? that would transfer a lot of heat into your oil line if they are touching.
The usual issue wrt to wide spaced headers is the rubber S hose that feeds the pressure pump from the oil tank. There are several solutions easiest is a thermal barrier placed between them
