964 Forum 1989-1994
964c4 Christmas tree + jerking + strange fixed voltage
Old 06-21-2018, 11:25 PM
Luftkühl
4th Gear
Luftkühl's Avatar
Default 964c4 Christmas tree + jerking + strange fixed voltage
Hello
could the community give me any clues about the diagnosis here?
Battery is brand new.
The jerking occurs only now and then: see YouTube video:
Thx for your efforts
cheers
Greg
Old 06-22-2018, 05:52 AM
LM964
LM964's Avatar
Same effect when idling and stationary and through any rev range?
Brake fluid at Max line and not a millimeter below? May want to check/clean; wheel speed sensors, accelerometers, swap out DME relay (R41) - just to rule this crtical relay out, check/swap out ABS relay (R34). Others will chip in with more suggestions. I have 2 C4's and those two relays I carry as on board spares.
Old 06-22-2018, 06:42 AM
newsboy
newsboy's Avatar
Running voltage should be between 13.8 and 14.4 volts, so perhaps the alternator?
Old 06-22-2018, 07:58 AM
JohnK964
JohnK964's Avatar
I kind of lean this way also in the video the voltage slowly dropped
Old 06-22-2018, 09:29 AM
Goughary
Goughary's Avatar
First thing to look at when you have xmas tree is your coils. In all likelihood they are going.
It's very common. We have all switched to 993 coils cuz i got frustrated changing coils too often.
There are a couple good diy threads on rennlist and ours is somewhere in the suspension madness thread
Old 06-22-2018, 01:27 PM
wallra
wallra's Avatar
to me it looks like not charging. should be at 14 volts
Old 06-22-2018, 05:02 PM
rsabeebe
rsabeebe's Avatar
man, i saw 'christmas tree' and 'jerking' and thought i better not open the thread!!
Old 06-22-2018, 05:07 PM
JohnK964
JohnK964's Avatar
😂😂 good one
Old 06-22-2018, 09:49 PM
Gmyres
6th Gear
Gmyres's Avatar
Happened to me a couple of times... turned out to be ignition wires resting on other electronic cables. I still have original ignition cables (1990 c2), but did not happen again after creating a separation.
Old 06-23-2018, 04:56 AM
Luftkühl
4th Gear
Luftkühl's Avatar
Ok
will start with the simple things: I do carry a spare DME in my glove box...but i didn't try swapping it yet
thx for your replies sofar: ill keep you posted
Greg
Old 06-24-2018, 07:26 PM
A914MAN
A914MAN's Avatar
When mine did that it was because the shop that worked on it right before I got the car had left a plug wire off. Drove home 725 miles no problem, 2 weeks after I got home I experienced the same trouble.
Old 06-24-2018, 08:56 PM
Luftkühl
4th Gear
Luftkühl's Avatar
Hello everybody
had very little time this weekend
@LM964: happens suddenly while driving, revving up is almost impossible because of the power loss due to the 'jerking' (have a look at the rev needle just above the multimeter in my film). I was lucky to be able to shoot this film at twilight, when there was little traffic and I was driving on a long stretch. When then car behaves like this, from the moment you let go the gaspedal (red light etc), the motor stalls. It is as if it has not enough momentum to keep running. At the end of the movie, even without letting go the gaspedal it stalled anyway.
The funny thing is that this comes up unexpectedly, now since three weeks.
I do think that my alternator is not loading correctly anymore, but the battery is brand new since one week and fully charged with a trickle charger (or what is the correct English term?). But its true: I think I will have to replace the alternator: ill make some footage when I swap the DME to show the charging voltage.
But I wonder if replacing the alternator will cure this strange behaviour since I did only a short ride with a fully loaded battery...
I am also intrigued by the fact that the voltage, as measured on the battery poles with the Fluke wireless display multimeter, stays exactly the same during when the car behaves odd?? Is there an explanation for this?
cheers from Belgium
Greg
Old 06-24-2018, 09:26 PM
Luftkühl
4th Gear
Luftkühl's Avatar
When I start changing the relais: does anyone know the cheaper VW part number for the R34 928-615-124-01 abs??
thx
Old 06-24-2018, 09:33 PM
JasonAndreas
Technical Guru
JasonAndreas's Avatar
thx
A faulty ABS relay will not cause the engine problem that you are experiencing.
Old 06-25-2018, 07:06 AM
newsboy
newsboy's Avatar
Change your coils, not expensive and easy to do.
Quick Reply: 964c4 Christmas tree + jerking + strange fixed voltage
