Calling on 6 speed conversion guys
Old 06-18-2018, 02:23 PM
merchauser
merchauser's Avatar
Default Calling on 6 speed conversion guys
researched and can't find answers: perhaps a few of those who have done 6 speed Z06 conversions can weigh in:
considering a 6 speed swap in my car, and wonder if folks are over the top happy, just neutral, or disappointed with results?
I have a stock engine and often wish I had another gear. doing the math, I can see that this would make the car a much
more enjoyable highway cruiser, but would like to hear about off the line performance.
at the lower end, are zero to 60 times faster, the same, or not as good? from previous posts, I can't decipher if there is only
the motorsports option for a kit to purchase? seems that others have done the conversion as well?
Old 06-18-2018, 02:31 PM
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,072 Likes on 1,183 Posts
The big question that's always in the back of my mind with this conversion, what are the negative effects from replacing or modifying the rear cross member? This isn't a trivial change or modification and most seem to overlook it.
Unless someone pays a ton of money to have the various ways to do this conversion fully stress tested compared to an original one, I'm not sure I'd ever be comfortable with this swap, as least with the various way's I've seen it done so far.
The rear cross member is one of the key elements of what makes the overall 928 chassis what it is. Cutting this up or replacing it shouldn't be taken lightly.
I don't understand this hang-up of having an engine at 3k rpm or even higher when going down the highway. It's not hurting the engine at all, and if that's such a bother, drop in a different 928 transmission with a 2:20 R&P.
I'm dropping in a different year trans into my 87 to shorten up the R&P.....
Old 06-18-2018, 02:51 PM
merchauser
merchauser's Avatar
In MY mind, I "think" the idea of having a lower revving engine at speed is just better; less wear and tear?? just the sound of lower rpm's make me think
that I am doing my car a favor.? please tell me I have no idea what I am talking about; lol I would love to hear that, and perhaps scrap this whole notion.
does lower rpm's help with the whole oil ingestion issue, which might not be an issue at all?? unfortunately, I read as much as I can, and I am sure a lot of
it is like a George Carlin quote on marketing and sales: "its all bull****, and its bad for you."
Old 06-18-2018, 03:13 PM
hacker-pschorr
I've been in the 928 word over 25 years and it's never concerned me.
Tiny German 4-bangers are designed to spin at 4k all day long down the highway (like my wife's Bug).
Lower rev's carry with them a different concern. Say you are now lumbering along at 1,500rpm with your Vette trans and decide to speed up and floor it, you are now in an area of the curve and with that load susceptible to engine damaging detonation otherwise rarely if ever seen with the stock unit.
Higher rev's are safer, and the idea of 3k-4k RPM's "wearing out" an engine may apply to your typical domestic V8, it doesn't apply to ours.
Old 06-18-2018, 03:22 PM
BC
BC's Avatar
And not really a problem for modern domestics anyway.
I would say being at 1800 rpm at 90 is very nice... But if the car isn't really designed for it...
Old 06-18-2018, 03:46 PM
merchauser
merchauser's Avatar
well, I like hearing that! perhaps the whole lower rpm idea is just concern for naught!
Old 06-18-2018, 04:04 PM
andy-gts
andy-gts's Avatar
I have had the 2.2 rear put in my gts when the engine was done and at 80 mph I am now at 2400 rpm ish and the sound of 3k is not there at all...love the new rear end.....would NOT switch to a 6 speed, I love the auto and we also have an 01 yellow vette convertible 6 speed and 2010 vette gs 6 speed and I can tell you shifting gets to be a pain on any car and no my old knees are fine.........just my 0.02 cents
Old 06-18-2018, 04:18 PM
77tony
77tony's Avatar
lets not forget that Andy's GTS^^is also a GB storker with more tq/hp than a stock GTS or GT in your case. I have a C5 Z06 conversion in Just Peachy with approx 550hp. Would advise to use this trans/diff set up in cars with a minimum of 400hp. Stock 928's especially OB's just don't have the power on tap to make this switch worthwhile IMHO. This mod can also relate to your driving style, location, and speed limits along with how much time is spent on highway driving. Many of TX highways are marked 75 and 85mph with little elevation change...makes a difference T
Old 06-18-2018, 04:33 PM
merchauser
merchauser's Avatar
can you expand on this a bit? IF (big if) I decide, I would be doing with stock engine. thanks
Old 06-18-2018, 05:08 PM
BC
BC's Avatar
Sorry, that is with my 7 spd in the C7. But I think the C6 trans are close.
Old 06-18-2018, 06:11 PM
Mongo
Official Bay Area Patriot
Fuse 24 Assassin
Mongo's Avatar
I'd bet a T56 6-speed and 3.90 gears would make any OB fun to drive, yet you can still cruise 70mph spinning 2700 rpm.
Old 06-18-2018, 07:04 PM
77tony
77tony's Avatar
by the numbers, a C6 Corvette Z06 weighs 3147lbs, has 505hp and 470tq. A 90 GT weighs 3505lbs with 330hp and 317tq. I've driven C6 Corvettes and IMHO have just enough pulling power to comfortably pass at the upper highway speed limits (75/85) without the need to shift down. In a stock 928 GT I'm guesstimating you'll need to shift down at least one gear for a comfortable pass. Again, it depends on your driving style, speed limits in your area, etc. If you do a lot of long distance travel the taller gearing may be for you and you'll now have have two overdrive gears to choose from. If you know anyone with a C5 or C6 Z06 Corvette ask them for a test drive and if not, look for one for sale in your area and take for a test drive as if you were thinking on buying. Like has been said^^you can swap in a taller final drive ratio that may be right for you. You'll also save plenty of time and $$$ by keeping it Porsche and that's not a bad thing...especially for re-sale down the road.02 T
Z06 1st gear - 2.66
Z06 2nd gear - 1.78
Z06 3rd gear - 1.30
Z06 4th gear - 1.00
Z06 5th gear - 0.74
Z06 6th gear - 0.50
Old 06-18-2018, 07:10 PM
merchauser
merchauser's Avatar
Like has been said^^you can swap in a taller final drive ratio that may be right for you. Will also save plenty of time, $$$ by keeping it Porsche's and that's not a bad thing...especially for re-sale down the road.02 T
thanks for info.
Old 06-18-2018, 07:50 PM
Bigfoot928
Bigfoot928's Avatar
Old 06-18-2018, 08:03 PM
merchauser
merchauser's Avatar
I had both the 2.20 and the 2.73 in the same car and it made a huge difference
I have 2.73 in my car, and not sure where I would go from there?? I have less of an interest in losing, off the line fun,
so I don't think a gear swap is an option
but the way the rear cross member is modified, it uses all of the factory mount points and the inner mount points for the cross member go through the outer part and the inner part on both sides. I'm good with the design.
did you make your own, or use the motorsport kit?
Quick Reply: Calling on 6 speed conversion guys
