K & N or no?
Old 06-16-2018, 04:08 PM
WALTSTAR
WALTSTAR's Avatar
Default K & N or no?
Is a K & N filter an improvement over the factory paper and why or why not?
Old 06-16-2018, 04:11 PM
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,549 Likes on 1,233 Posts
No.
Old 06-16-2018, 04:50 PM
WALTSTAR
WALTSTAR's Avatar
Why, may I ask?
Old 06-16-2018, 04:53 PM
Mike Murphy
Mike Murphy's Avatar
Received 1,578 Likes on 985 Posts
No. Two reasons:
1.) The K&N, If not carefully cared for, can actually pass more dirt through it compared to the stock filter.
2.) Porsche thought through the entire intake through exhaust and there’s not much or any benefit to upgrading the air filter.
Old 06-16-2018, 04:57 PM
Crumpler
Crumpler's Avatar
The traditional knock on the Oiled filters is that it will interfere with the MAF sensor hot wire. I believe it’s a non issue in older models without a hot wire.
Edit: and what Murphy said above,
Old 06-16-2018, 06:04 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,243 Likes on 1,241 Posts
In addition to whats been posted above,
the knn filter also leaks dirt around the edges ,
(look at the lower aircleaner housing at the next knn filter you remove, bet you find sand in the oily areas.)
and thus allows more fine particulate into the combustion chambers.
Best bet for max performance and engine life use the stock filter with the hump facing the sky.
If you have to spend money on the car ,
then buy a new set of shocks ,
this will do more for the car than any air filter ever could
Old 06-16-2018, 06:29 PM
V2Rocket
Rainman
V2Rocket's Avatar
Good way to kill a hotwire MAF sensor and spend $50 while doing so.
Old 06-16-2018, 07:24 PM
Crumpler
Crumpler's Avatar
Yes, but if you order now you can get a free hat!
Wait, I watched this link and it occurred to me that last time I ordered a Stock filter from Roger there was no soft **** or crushed cars included — what the hell man!
https://www.knfilters.com/mobile/2017_calendar_BTS.html
Old 06-16-2018, 09:54 PM
WALTSTAR
WALTSTAR's Avatar
Thank you all, changed it back out to a new factory filter. My 84 does not have a hotwire, does it?
Old 06-17-2018, 04:35 AM
Strosek Ultra
Strosek Ultra's Avatar
Many years ago I dynoed my 1985 928S Euro with stock paper filter, with K&N filter and without filter. No difference in performance could be seen.
Åke
Old 06-17-2018, 05:22 AM
Red Flash
Red Flash's Avatar
Back in about 1994 - 1996, I was running a K&N on my 1986 900 Turbo bolted directly onto the air mass meter. I really liked the sound effects during acceleration when you could here the boost pulling air through the intake. Really gave me an appreciation for the importance of a well designed low-drag intake. That having been said, it did not destroy the air mass meter and it did not seem to improve the performance. Frankly, I would just keep the stock filter.
Old 06-17-2018, 09:56 AM
Rick Carter
Rick Carter's Avatar
Åke
I did the same thing with my '85 32v with the same results.
Old 06-17-2018, 02:24 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
its the dirt that gets past it that you also dont see, stick with the Factory filter,
you will never lose a race because you have a factory filter
Old 06-17-2018, 02:36 PM
Speedtoys
Speedtoys's Avatar
Received 1,034 Likes on 623 Posts
Air falls into turbos...as odd as it sounds, they dont suck.
BUT...consider that if you can hear more, you are filtering less.
Yes, there are likely cars with too small of a filter to get enough filter surface area, but the 928 isnt one of them.
Old 06-17-2018, 03:42 PM
Red Flash
Red Flash's Avatar
Actually, I ascribed the noise to the much less plumbing that also opened to the side of the wheel well that I did away with while I had the K&N on. Not sure, if it had anything to with the amount of filtering or not. The plumbing somehow attenuated the noise.
In any case, the motor is still in excellent shape and takes no oil and has perfect compression. So, the K&N did not appear to harm the motor. Then again, it's a completely different set-up than the one that goes into the 928.
Quick Reply: K & N or no?
