Parts Search
Keyword:
Category:
Price (no $ sign please):
Private or Vendor Listing:
Location (Region):
Item Condition:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Cont. Porsche Models:
Color:
Private or Dealer Listing:
Location (Region):
Transmission Type:
AUTO-BLiP - Blips the Throttle on DOWNSHIFT!
Old 06-13-2018, 08:17 PM
RennKit-Dave
Basic Sponsor
RennKit-Dave's Avatar
Default AUTO-BLiP - Blips the Throttle on DOWNSHIFT!
Category: Engine - Electrical
Price (no $ sign please): $390
Private or Vendor Listing: Vendor Listing
Part fits (select ONLY those which apply): 986, 987, 996, 997, Cayman
Location (Region): Midwestern
Item Condition: Brand New
Rennkit is proud to offer the innovative AUTO-BLiP device to blip the throttle on downshift!
Hear it on the track with a GT3 at www.rennkit.com
AUTO-BLiP is an electronic device that automatically blips the throttle when downshifting gears on a manual transmission Porsche. AUTO-BLiP works by monitoring your Porsche 996/986 or 997/987 Series accelerator pedal position sensor, brake pedal, and clutch pedal, and only blips the throttle when both brake and clutch pedals are pressed simultaneously. Six wires to tap into - nearly plug and play. AUTO-BLiP reduces mechanical wear and tear on manual transmissions, improves vehicle stability when downshifting gears, and eliminates the need for the heel-and-toe driving technique.
Features
AUTO-BLiP simply connects to your vehicles throttle pedal position sensor, brake pedal switch, and clutch safety interlock switch using the supplied T-Tap connectors. Almost PLUG & PLAY!
On-the-fly tuning capability using two dials. Set the desirable RPM blip level and a time delay from downshift until throttle blip.
Simple one-time calibration routine easily interfaces to your Porsche's OEM sensors. Once installed, a 6-step calibration routine allows it to learn the throttle, brake, and clutch configuration.
Four LEDs display functional status. AUTO-BLiP provides the driver with a simple yet easy to view status of the brake pedal, clutch pedal, and blip events.
Check out the AUTO-BLiP and other novel products at www.rennkit.com
  • Rennkit eRam Kit - NO MORE WING HYDRAULICS!
  • Rennkit Bluetooth Retrofit Kit
  • Rennkit Cayman/Boxster Wing Extender
  • Function F1RST - Shifter extender - Shift ***** - Transmission mount inserts
  • Phenix Engineering - Suspension upgrades - RWD conversion kit
  • OS Giken - LSD
  • Zunsport - Mesh Grills
  • Girodisc - 2-pc Light Weight Brake Rotors
  • Tail-Light FiX and Airbox Clips
Dave
Rennkit
djcooper@rennkit.com
http://rennkit.com/
  • Patented eRam Kit™ for 996/997 Turbo & Carrera GT wings
  • Cal*Cool™ - brake cooling 996/997 / Bluetooth Retrofit Kit™ for 1998-2011 cars / Wing Extenders™ 987 Cayman / 997 Turbo
  • AUTO-BLiP for MT / Function F1RST Shift ***** / Girodisc 2-piece rotors / OS Giken LSD / Phenix suspension / Zunsport grills / 997/987 switches/PCM ***** / Border Coilovers
RennKit-Dave is offline
Old 06-15-2018, 11:06 AM
dc2000
dc2000's Avatar
I've seen this but don't know if it actually works in my 2010 Carrera S. Will this work and is it really plug and play?
dc2000 is offline
Old 06-15-2018, 11:17 AM
HarmonyJim
HarmonyJim's Avatar
I was wondering the same thing. On my set of Tractive shocks and DSC controller, Tom at TPC put up a series of instructional photos to illustrate exactly what is required to wire the DSC (and required accelerometer) unit into the harness. This removed much of the anxiety when I was considering cutting into my insanely-expensive OEM wire harness. The same process here would alleviate much of the anxiety we potential installers have. Check out Tom's postings on RL (he also utilized a pencil drawing illustrating the wiring modifications).
HarmonyJim is offline
Old 06-15-2018, 01:33 PM
DaveCarrera4
DaveCarrera4's Avatar
Great questions! Yes it is nearly plug and play. 3 T-Taps added to the clutch, brake and throttle wires - no cutting. I'm installing one this weekend (either my turbo or a friend's turbo). Which give me the idea to to video the whole process start to finish. I'm guessing 30 - 60 minutes if we take our time and video the whole thing.
DaveCarrera4 is offline
Old 06-15-2018, 05:55 PM
skyak
skyak's Avatar
Please do. Also would be interesting to see where you can install it so it is out of sight but you can still access the on/off easily.
skyak is offline
Old 06-15-2018, 07:03 PM
The Radium King
The Radium King's Avatar
it fits in the ashtray of a 986 or 996 ...
The Radium King is offline
Old 06-15-2018, 08:27 PM
Dguth
Dguth's Avatar
Very interested in this. Please post DIY and if you have video of how it sounds.
Dguth is offline
Old 06-15-2018, 08:45 PM
skyak
skyak's Avatar
Nice. Is the wiring out of view?
skyak is offline
Old 06-15-2018, 09:24 PM
RennKit-Dave
Basic Sponsor
video on home page, www.rennkit.com. We are pretty excited about this product. I learned to heel and toe, but dropping that move will not make me sad. Stay tuned for the install video.
Old 06-15-2018, 11:00 PM
The Radium King
have not completed install yet, and can't speak for a 9x7, but from initial inspection should be able to drill a hole in the ashtray (perhaps with a small grommet to make it look clean) and run wiring under console to dash, where it connects to the wiring coming from the pedals (throttle wire, and wires from the microswitches on the clutch and brake pedals). ashtray even has a cover for when not in use, and a little light to illuminate it. perhaps mr rennkit can include in his install video?
Old 06-16-2018, 02:09 AM
VID997
VID997's Avatar
Mounted in my 2009 997.1 TT...it works.. ; ]
VID997 is offline
Old 06-16-2018, 03:34 PM
IX XI
IX XI's Avatar
Will this also work on the NA 997s? If not, any plans to make a version that does work with the NA cars?
I'd definitely be interested if so.
IX XI is offline
Old 06-16-2018, 03:59 PM
skyak
skyak's Avatar
Group buy?
skyak is offline
RennKit-Dave
Basic Sponsor
Absolutely - vehicle just needs an e-throttle.
Group Buy?
Sure, first 10 guys - for 10% off. Must send a few pictures of the finished install - and any you could take during the install.
To get in on this discount: Send an email to me at
djcooper@rennkit.com (no PM's).
Old 06-16-2018, 07:23 PM
Jett911
Jett911's Avatar
[QUOTE=RennKit-Dave;15083864]Absolutely - vehicle just needs an e-throttle.
Group Buy?
Dave, I just ordered one of these from your site yesterday... Any chance I can retro-actively join the Group Buy?
Jett911 is offline
Quick Reply: AUTO-BLiP - Blips the Throttle on DOWNSHIFT!
