How to compute / plan racing line
Hello. Not sure if someone asked before but I could not find anything. I understand the racing line can have many factors such as elevation change, camber, and actual racing condition. I understand best way is to drive the line and test it out. However, is there a standard method to compute ideal racing line just based on map?
I am using circle and straight line to connect each other. No clue if this is correct or not. Please advise.
Basic Site Sponsor
Basic Site Sponsor
Location: Durham, NC and Virginia International Raceway
Received 2,799 Likes
Basic Site Sponsor
Basic Site Sponsor
Very?
Shouldn't be...
This is my favorite "simple" explanation. http://speedsecretsweekly.com/wp-con...s-Weekly-1.pdf
IF the car is driven to the limits of it's adhesion, AS MUCH OF THE TIME AS POSSIBLE, the line is defined BY physics, FOR the particular driver/car combination.
Not the other way around...
Twenty pages...
Shouldn't be...
Twenty pages...
-Peter Krause
www.peterkrause.net
www.gofasternow.com
"Combining the Art and Science of Driving Fast!"
Specializing in Professional, Private Driver Performance Evaluation and Optimization
Consultation Available Remotely and at VIRginia International Raceway
-Peter Krause
www.peterkrause.net
www.gofasternow.com
In a perfect world its actually 2 parabolic curves (corner entry and corner exit are separate curves) and a straight line. That part you could probably compute.... Real world you have to throw in things like camber changes, bumps and pavement changes that will complicate the prototypical line.
Many novice drivers need to understand exit speed is critical as is what is the next corner all about.
Basic Site Sponsor
Basic Site Sponsor
Bingo. First step, period.
Yes.
WRONGLY ACCUSED!
Received 3,238 Likes
Following someone who knows the line is usually the best way for me. If I am at a new track I find a "local" and latch onto their bumper.
Very?
Shouldn't be...
Twenty pages...
Shouldn't be...
Twenty pages...
As for the racing line I was moreso referring to defensive vs open laps and maybe slightly more tire wear friendly line when doing laps 2-3 seconds off max pace.
Latch on...
"find a "local" and latch onto their bumper". Great advice!
Thanks for all the input. I totally understand actual ideal racing line can be different during actual driving. However, I am just trying to find out how I can properly (mathematical formula / method) draw out the ideal racing by just looking at map and put away all other possible factors of camber, bump, elevation change, and etc.Simply looking at the google satellite map.
Basic Site Sponsor
Basic Site Sponsor
The exceptions are well known by folks that study them. The aforementioned Road Atlanta T2 and T11, VIR T4A and T4B, Summit Point Turn 4-Turn 5... The list goes on, but I think Glen's comment (the perusal and study of the Google Earth maps) is the best starting point.
George's recommendation is SUPERB. It was actually Alan Johnson who was the author (and a successful Porsche dealer and multi-time National Champion) with Richie's input, who wrote "Driving in Competition," here:
https://www.amazon.com/Driving-Competition-Alan-Johnson/dp/0393600114/ref=sr_1_1?s=books&ie=UTF8&qid=1526926328&sr=1-1&keywords=Alan+Johnson+driving+in+competition
What Alan did before anyone else was to study similarities in the most efficacious way through particular corners, then classify them one of three different ways, Type 1, Type 2 and Type 3, in order to standardize the approach, prioritize and optimize performance through each of them.
You should get this book as well, because it's still a reference for folks who are trying to do this 42 years later. I think a new version was scheduled to come out
Basic Site Sponsor
Basic Site Sponsor
What did the driver DO? THAT is the question...
This is a major part of my approach. I spent several years running 15-20 autocrosses a year. You have to learn a new course and new line at every event. It's always a balance between conserving speed and shortening the distance between corners. Every third or fourth corner I'd look back and see if the planned line was still going to be effective, or if a new course element required me to place the car elsewhere for a better exit from the next corner. Knowing where you want to end up makes it much easier to see the path leading up to it. You can't look at every corner as an individual event and rely on starting wide, clipping the apex, and tracking back out to result in the fastest lap time.
As was mentioned by another, the physical track surface and topography will have an impact on your racing line as well. You can look at satellite views and plan ahead for when you arrive, but you'll have to adjust your line if there are bumps which impact braking, cornering, or accelerating. During an event you may find yourself adjusting your line as people start dropping wheels off track and drag dust and debris back on. Your entire line can change when it rains as the normal racing line might be slick with oil that inevitably drips off cars, or the rubber embedded into the racing surface is now slippery. Then you add in the up or down hill nature of a corner and it changes things again.
