How may turns to raise/lower my car?? (Turns of the suspension coil nut)
Seems to be a common set of questions, because how much on the nut is a 10mm rise or fall??
Well, I put this together to help. Requires Excel, has a handy macro to reset the values you wanna start over.
Right-Click to download the worksheet:
928 Height Adjustment Worksheet
Agree, this should be a sticky or in the Rennlist DIY section. The pictures of what to turn, which direction for higher and lower, and the tool reference are very helpful, too.
I was asked about if you measure on a grade..what about that?
Well, on a 2% grade, which is just over 2" of elevation difference between both ends (A lot for any flat-ish driveway or street) I got these values:Front Correction-0.40%Rear Correction0.55%Weight Lost To Gradient-2.9438
Gonna just assume losing 3lbs of the mass of the car at a 20" vertical CoG in a driveway when measuring chassis height...aint gonna matter.
Now, right to left curb weight and then adding driver weight might need some adjustment, but need corner scales next month to see how driver weight moves around.
If I sit in my car and add 62lbs to the drivers rear corner, that seems to mean 8.5mm of spring compression...I think...
Im a looking at an updated formula to work out motion ratio.
if I look at these two dimensions, D1 and D2, on my S4, and I do a simple D1/D2, I get ~.8, as previously reported here on RL by others.
But if I use Koni's formula, (D1/D2)^2, I get a MR of ~3.5, which dramatically changed my front adjustment number. And those are the #s that I went with on collar adjustment yesterday while swapping shocks.
I will let this settle for a few days, and report back, and make any needed adjustments/observations.
