Light Weight Battery for .2 GT3???
Old 04-11-2018, 09:49 AM
TexasPorschelover
TexasPorschelover's Avatar
Default Light Weight Battery for .2 GT3???
Has anyone done this <10lbs battery conversion?
https://rennlist.com/forums/gt2-and-...r-the-gt3.html
Love to hear more.... reliable?.... issues?..... etc...
Old 04-11-2018, 09:58 AM
911therapy
911therapy's Avatar
I did it on my 991.1 GT3. Went with the Voltphreaks VP6. Weighs right around 6-7 lbs. Works beautifully. I drive the car at least every two weeks so I do not even leave it on a trickle charger. Plus, it has the cutoff point, so it always has one start in it. Very impressed.
Old 04-11-2018, 10:06 AM
TexasPorschelover
Thank you - good to hear - 40 lbs weight savings is pretty substantial. Voltphreaks websites says the following
Almost all car alternators maintain 14V to 14.6V to properly charge the car's battery, and this is what the Voltphreaks battery expects. Some Porsche GT's undercharge their lead-acid batteries, and this is not compatible with the more efficient lithium batteries. Below 13V, a lead-acid battery will be partially charged, but a lithium battery will be barely charged. If you have a Porsche GT2 or GT3 (or if you suspect your car's voltage may be incompatible), measure the voltage with engine on (so alternator is active) first to insure compatibility. Voltage at idle should be around 14-14.6V.
I assume the .1 and .2 are fine bc they charge at 14.6v?? Checking bc my .2 hasn’t arrived yet so don’t know for sure. Thank you.
Old 04-11-2018, 10:14 AM
911therapy
911therapy's Avatar
My 2015 GT3 alternator charged right in the 14.5 range. It was spot on. I think there was only a few 991 GT3's that had the lower-than-normal alternator charge. No way to know for sure until yours arrives, but I would be fairly certain that a new 991.2 GT3 will at least charge at 14V
Old 04-11-2018, 10:33 AM
TexasPorschelover
Super. Did you lower the front end to compensate for the 40lbs weight savings?
Old 04-11-2018, 10:59 AM
qbix
qbix's Avatar
I compensate before and after dinner.
MM-Racing (03-19-2021)
Old 04-11-2018, 11:43 AM
FourT6and2
FourT6and2's Avatar
Is it really a good idea to remove weight from the front of a GT3 since most of the weight is in the rear?
Old 04-11-2018, 12:25 PM
BCMgunner
BCMgunner's Avatar
I may do this to counter all the wine in the frunk returning from Fredericksburg/Hill Country.
Old 04-11-2018, 12:32 PM
TexasPorschelover
Depends if you have the larger fuel tank or not I suppose. In general removing 40lbs is a good thing. Thats half a sack of concrete the car is no longer lugging around. If you do the exhaust 15-20lbs comes off the back too (depending on the exhaust) but combined 55-60 lbs is super.
Old 04-11-2018, 01:19 PM
drdonger
drdonger's Avatar
This would be a great mod in conjunction with an exhaust. Anyone know how exactly much the OEM 991 gt3 battery weighs?
Old 04-11-2018, 01:39 PM
LoloM
LoloM's Avatar
Do you guys know why there is no OEM option for the lithium battery in the .2 GT3 / RS and GT2 RS ?
Old 04-11-2018, 01:43 PM
usctrojanGT3
usctrojanGT3's Avatar
Received 3,789 Likes on 2,158 Posts
Originally Posted by drdonger
This would be a great mod in conjunction with exhaust.
Yup, remove those side muffler paperweights at the same time and now you've dropped 80lbs off the car.
Old 04-11-2018, 02:11 PM
Jimmy-D
Jimmy-D's Avatar
Received 1,382 Likes on 719 Posts
I did a write up on this about 2 years ago, on this forum, after a long exhaustive search for the all-around best if you want to try to find it.
The Braille is the best and plug and play. The Voltphreaks you needed to build a bracket to properly hold it in place unless they have developed one. The Braille also is better for those in colder weather areas like the Midwest and NE. I think the Braille was only like 3 lbs heavier than the Voltpheaks which is negligible
Old 04-11-2018, 02:13 PM
Jimmy-D
Jimmy-D's Avatar
I think 35-40lbs. I recall my Braille was a 25 lbs savings which is significant if you ever picked up a 25 lbs weight at the gym
Old 04-11-2018, 02:54 PM
drdonger
drdonger's Avatar
Voltphreaks developed a bracket that is 2.4 lbs. With the bracket you are looking at 8 lbs total. Thats a 35-40lb weight saving over stock.
Quick Reply: Light Weight Battery for .2 GT3???
