993 Forum 1995-1998
Check Engine light came on this morning on way to work. 95 80k
Old 03-22-2018, 11:10 AM
gmorat
gmorat's Avatar
Default Check Engine light came on this morning on way to work. 95 80k
I recently swapped the battery on my car cos the old one died over the weekend. The car sat for day maybe with a completely dead battery. I just had the carpet replaced. These are the only things that have changed in the last few months. I was driving along and the car felt good when the check engine light came on. I wasn't driving hard. It just turned on. It turned itself off again when off the gas but would light up when power was applied at anything more than a tickle.
I was fortunate that my specialists place is close to where I was going anyway so I just drove it there instead and left it with them.
My car is a 95 with 80k on the clock.
Old 03-22-2018, 11:55 AM
Gbos1
Gbos1's Avatar
SAI Cleaning in your future ..... . . . . .. . scan will tell all
Old 03-22-2018, 11:56 AM
gmorat
gmorat's Avatar
It's a ODB1 95, I thought they didn't throw SAI codes?
Old 03-22-2018, 12:03 PM
P-daddy
P-daddy's Avatar
No SAI CELs for 95s.
Old 03-22-2018, 12:12 PM
Gbos1
Gbos1's Avatar
Ah my bad! That's right
Old 03-22-2018, 01:45 PM
993Brendan
993Brendan's Avatar
The one time this happened in my 95 I didn't tighten the gas cap enough. Took it off, make sure it clicked a few times and the light went off. Worth checking- easy and free
Old 03-22-2018, 02:12 PM
gmorat
gmorat's Avatar
This one I can handle!
G
Old 03-22-2018, 03:02 PM
gw911nine97
gw911nine97's Avatar
re-check battery connection, maybe give the wire terminal insides a quick clean before reconnecting them to their battery terminals.
Also check fluid level of new battery & top up if necessary.
Old 03-22-2018, 03:39 PM
SpeedyC2
SpeedyC2's Avatar
^ Worth a check. I had a loose connection at the battery cause some odd symptoms once.
Old 03-22-2018, 03:58 PM
nine9six
nine9six's Avatar
All of what I read above is guessing...
Hook up even a generic OBD1 scan tool and see what code(s) are thrown, and now you can move forward with some real information rather than a guess.
A check engine light can be thrown for any myriad of reasons.
Old 03-22-2018, 04:45 PM
evilfij
SJW, a Carin' kinda guy
evilfij's Avatar
Check and replace (if needed) the seal on the gas cap. They go bad. And yes, they are available separately from the $130 gas cap, which I found out after the fact ....
I never got a code, but it failed emissions as the cap would not seal.
Old 03-22-2018, 05:44 PM
coreseller
coreseller's Avatar
This one fits, already replaced mine about a month back:
Volkswagen OEM 191201557 WASHER
https://www.amazon.com/Volkswagen-OEM-191201557-WASHER/dp/B01CZ2TPRY/ref=sr_1_1?s=automotive&ie=UTF8&qid=1521751450&sr=1-1&keywords=Volkswagen+OEM+191201557+WASHER https://www.amazon.com/Volkswagen-OEM-191201557-WASHER/dp/B01CZ2TPRY/ref=sr_1_1?s=automotive&ie=UTF8&qid=1521751450&sr=1-1&keywords=Volkswagen+OEM+191201557+WASHER
Old 03-22-2018, 06:47 PM
woohoosocal
woohoosocal's Avatar
O2 Sensor - easy to change. Mine would come on for a minute and then go off never to be seen again. Until, maybe, I drove it again, but not every time.
Old 03-22-2018, 07:14 PM
P-daddy
P-daddy's Avatar
Agreed
Old 03-23-2018, 04:40 AM
Railmaster.
Railmaster.'s Avatar
If the fluid level in the battery is so low that it causes a CEL it is most likely too late to save it by topping up the battery!
And apart from that the correlation between low battery fluid level and CEL is a real longshot! But I have seen stranger things passing!
Quick Reply: Check Engine light came on this morning on way to work. 95 80k
