Parts Search
Keyword:
Category:
Price (no $ sign please):
Private or Vendor Listing:
Location (Region):
Item Condition:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Cont. Porsche Models:
Color:
Private or Dealer Listing:
Location (Region):
Transmission Type:
993 FVD Solid Racing Subframe Tilt Kit
Old Mar 18, 2018 | 12:22 AM
Foxman's Avatar
Foxman
Default 993 FVD Solid Racing Subframe Tilt Kit
I just removed these from my 993 C2S while rebuilding the suspension. This solid tilt kit is based on the 993 GT2 design. It provides an incredibly low and firm ride. See the write up below from FVD for more details. This kit typically sells between $500 and $750. Will ship anywhere in CONUS for $200, PayPal fees included.
Description from FVD:
Solid bushings and mounts allow you to achieve exact suspension articulation which improves handling and stability on lowered / race prepared cars. The original soft rubber bushings can deform under track loads which allows the sub frame to shift and throw the camber and toe off. Solid bushings will not deform and will keep the camber and toe settings in line which equates to confidence in cornering and faster lap times.
These are intended to replace the soft rubber bushings on the original rear sub frame (part #’s 993 331 051 00 & 993 331 052 00). They are made in Germany and are TUV approved.
Old Mar 18, 2018 | 11:47 AM
OverBoosted28's Avatar
OverBoosted28
If someone wants just the solid subframe inserts, I’d take the tilt items. I already have the solids, w/o tilt. LMK.
