Parts Search
Keyword:
Category:
Price (no $ sign please):
Private or Vendor Listing:
Location (Region):
Item Condition:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Cont. Porsche Models:
Color:
Private or Dealer Listing:
Location (Region):
Transmission Type:
Go Fast Bits DV+ TMS Diverter Valve #T9301
Old Mar 16, 2018 | 06:00 PM
KEVIN ANDERSON's Avatar
KEVIN ANDERSON
Default Go Fast Bits DV+ TMS Diverter Valve #T9301
Category: Engine - Intake/Fuel
Price (no $ sign please): $135
Part fits (select ONLY those which apply): 924/931/944/951/968, 964, 987, 993, 996, 997, Cayenne
Location (Region): NorthEast
Item Condition: Brand New
I have a brand new, only taken out of the box to look at, Go Fast Bits Diverter Valve with 25mm inlet and outlet. It is a direct replacement for the plastic Bosch diverter valve. I had a customer order it, then cancelled the order. It will fit any car that uses the 25mm Bosch diverter valve. This is made in Australia and the quality is top notch. It installs differently than the stock valve. No amount of boost can make it leak because it has equal vacuum and boost pressure on either side of the O-Rings and piston. Comes with an Allen key and 4 different spring tension bolts. Shipping is $13.00 to the US.
Much faster throttle response and has a lifetime guarantee Look up the part number and read about it. I'm giving you a pretty good discount. Thanks, Kevin I will ship worlwide
Standard photo
Performance graph
What you will be getting
What you will get
