Steering wheel replacement
Old 02-18-2018, 09:42 PM
leon yagudayev
leon yagudayev's Avatar
Default Steering wheel replacement
Hi. Quick question , I have 2010 c2s PDK. My wheel is non heat non multifunctional pushbutton . I wanted to swap for heated pushbutton multifunction wheel. The dealer says not sure if its possible something bout VIN may not allow to program it. Does it sound like b.s.? Thanks
Old 02-19-2018, 07:49 AM
Petza914
Petza914's Avatar
Received 6,140 Likes on 3,913 Posts
I added multifunction buttons to my .1. Not sure if the .2 is more restrictive.
Old 02-19-2018, 11:25 AM
ltcjmramos
ltcjmramos's Avatar
Slightly OT, but how about swapping in a wheel (991?) that has Sport Chrono buttons on the wheel, paddles preferred?
Old 02-19-2018, 07:47 PM
leon yagudayev
So the dealer says cannot be retrofited at all. Another Indy guy says it can . I don't know exactly who is right. I want the multifunction but don't want to buy it and then not able to use it
Old 02-19-2018, 10:09 PM
Dartmouth
Dartmouth's Avatar
Yes you can do it. I did it. Swapped out the original
wheel to a multifunction wheel with heat. Bought a wood/leather wheel kit from Suncoast Porsche Parts in Florida. Comes with shift **** and brake handle for about $1500. I had Porsche of Monmouth install it and program it. No Problem.
Old 02-19-2018, 10:15 PM
leon yagudayev
Yeah it seems like Suncoast says its no problem buy my dealer doesn't think its possible saying codes are not available for cars 2010 and up (???) I'm gonna call another dealer
Old 02-20-2018, 06:20 PM
myw
myw's Avatar
you will need the Paul Li adapter i believe (no affiliation).
Old 02-20-2018, 06:31 PM
Yuan Li
Yuan Li's Avatar
Upgrade to heated steering wheel need replace clock spring with heating supported version,’heating steering wheel enable code’ and ‘Multifunction enable code’ needed also for 991.1.
Active multifunction and heating need program vehicle following this guide https://gpsadapter.us/blogs/installa...n-coding-guide
Old 02-20-2018, 07:10 PM
ltcjmramos
ltcjmramos's Avatar
I have 2012 997 GTS, PDK with paddles, no heat. Can anyone give me the p/n for the 991 wheel that has the Sport Chrono on the wheel, no heat?
Old 02-20-2018, 08:06 PM
Yuan Li
Yuan Li's Avatar
991.044.400.01.A34 black leather with PDK display
Old 02-20-2018, 11:17 PM
ltcjmramos
ltcjmramos's Avatar
Woops!! Buttons only. Deal breaker. Gotta have my paddles. Thanks
ed: I was wrong. The p/n provided is with paddles but at $1016 I'm not sure it's worth it to me. Most of the time, I'm in Sport. I think my wife gets more nervous about me looking down to switch it on/off.
Old 02-21-2018, 07:09 PM
y2says
y2says's Avatar
I'm not a fan of the multi-functional wheel either. I find myself changing the station or volume on accident all the time.
Quick Reply: Steering wheel replacement
