996 Forum 1999-2005
FABSPEED MOTORSPORT | 996 Sport Headers
Old 02-14-2018, 04:47 PM
John@Fabspeed
Basic Sponsor
John@Fabspeed's Avatar
Default FABSPEED MOTORSPORT | 996 Sport Headers
One of the biggest constriction points on the 966 Carrera is the OEM Manifolds as exhaust scavenging and flow are compromised due to uneven OEM Primary Tubes.
One easy way to mitigate this issue is Fabspeed's equal length Sport Headers. Our Sport Headers provide improved torque and equalized engine pulsing thanks to industry-exclusive mandrel-bent primary tubes.
Fabspeed's Sport Headers are a direct bolt-on upgrade/replacement of the factory headers on all Porsche 996 Carrera vehicles. Creates+15 HP (whp) +12 TQ (ft/lbs) and saves -2 lbs.
  • Fits all Porsche 996 Carrera vehicles 1998-2004
  • Improves horsepower and torque by 15 whp and 12 ft-lbs
  • Saves 2 lbs from the rear of the vehicle
  • One piece CNC mandrel-bent primary tubes provide maximum uninterupted flow
  • F1-style merge collectors provide optimized exhaust scavenging
  • Improves power and torque throughout the RPM range
  • Direct replacement for the factory headers
  • Simple DIY bolt-on installation
  • All Fabspeed performance products are backed by the Fabspeed Lifetime Limited Warranty
  • IN STOCK & READY TO SHIP
https://www.fabspeed.com/porsche-996...sport-headers/
Please feel free to PM me with any questions or for forum pricing
Porsche Performance Specialist
John@Fabspeed.com
215-618-9796
Fabspeed Motorsport USA
155 Commerce Drive Fort Washington, PA 19034
www.Fabspeed.com
Old 02-14-2018, 08:01 PM
RngTrtl
RngTrtl's Avatar
are there dyno sheets to back this up with the headers being the only mod?
Old 02-17-2018, 12:33 PM
Jnelso
Jnelso's Avatar
I have Fabspeed mufflers, interested in installing these Fabspeed Headers, but I have seen that one can never get all the bolts out when removing the old headers without breaking one or more studs. Anyone that may have removed their headers ever dot it without breaking any of the studs. If you did break any, how succesful were you removing the broken stud.
Old 02-17-2018, 03:32 PM
roadblock
roadblock's Avatar
I have broke one on each side - I put it in vice and used a pointed punch and knocked it out- it takes a few good smacks with heavy hammer
Old 02-17-2018, 07:06 PM
trendy996
trendy996's Avatar
Tighten the bolt slightly before breaking loose. That’s the best way. Might be even better to also add heat. Using the stomski tool makes it easy.
Old 02-17-2018, 07:48 PM
Jnelso
Jnelso's Avatar
Ive heard talk of the stomski tool, exactly what is it and where do you get one?
Old 02-17-2018, 07:56 PM
roadblock
roadblock's Avatar
Stromski is a tool - you don't need to extract if it does not break - save your money, the stromski work well if you break a header bolt off in head
Old 02-18-2018, 03:18 AM
Vancouver996
Vancouver996's Avatar
Lol , in takes , chipped , headers , 200 cell cats and mufflers 8 k spent , youre lucky to see 8 hp total improvement on a motor that sees 100 hp/ litre stock on the rolling road
Old 02-18-2018, 08:24 AM
David993S
David993S's Avatar
Everything Fabspeed sells adds significant hp and torque...........yeah, right.
Old 02-18-2018, 10:33 AM
Jnelso
Jnelso's Avatar
You are probably right, without other mods just replacing exhaust system wont do much for performance.
Old 02-18-2018, 01:39 PM
TonyTwoBags
TonyTwoBags's Avatar
Headers, chip, intake, mufflers, cat seem to do a lot more than 8hp. More like 20-30rwhp at various parts of the rpm range.
Old 02-18-2018, 02:14 PM
Vancouver996
Let's see the test sheets
Old 02-18-2018, 04:50 PM
dan_189
dan_189's Avatar
I personally havent done this before but i read a procedure once of:
- drive car to get the engine hot
- soak bolts in pen fluid overnight
- resoak then remove
That was by memory but seems to make sense
Old 02-18-2018, 07:52 PM
TonyTwoBags
Old 02-18-2018, 07:55 PM
dan_189
dan_189's Avatar
Here we go...
Quick Reply: FABSPEED MOTORSPORT | 996 Sport Headers
