Carbonio license plate GT3
Hi, What do you think about the carbon license plate? no cooling problem ( on street for track I remove ) a better system exist? thanks for advice ( im in France)
https://www.carbonio.com/Porsche_991...por-991gt3.htm
I have the Carbonio for my GT3. You can see pictures and how it worked out here. https://rennlist.com/forums/991-gt3-...k-mount-4.html
I don't leave it on the car (which is the reason I bought it in the first place) so I don't know if it will affect cooling. I suspect that it won't be a problem on the street. I did modify it a little to make it work better. I like it and would buy it again.
I've seen cars with license plates mounted on the tow hook mount but I don't like the unbalanced look.
Some people have installed magnets behind the bumper cover and on the factory license plate holder. That looks good but it's a lot of work.
Edit: I just sent them an email with links to both threads so I expect we'll get their opinion sometime soon.
I mounted two 1" round rare earth magnets to the inside of the center grill. I glued a piece of ferritic stainless, magnetic, to the back of my plate to match the position of the magnets. Trimmed the height of the plate to slightly less than the opening height and then wrapped the edges of the plate with Expel to avoid any damage while removing/installing the plate.
I've tested it at 80 mph on the road without issue. It is easy to put on and take off.
I got a Carbonio for my .2 GT3. I contacted the company and they assured me that the one the version they made for the .1 would work for the .2. As you know, the .2's grill is not vertical relative to the road but rather angled to it. It makes it a bit more tricky to put on IMO (see pic). As for cooling, I have no idea but I'll be sure to be mindful of it as I drive back and forth from the track.
I use US Millworks tow hook plate. Great quality product made out of aluminum. Works great, easy to get on and off, and only slightly overlaps with the grille.
Here is a quick pic I found online. It sits the same on my .2, but you can adjust up/down, left/right based on where you mount the bolts
So far, clipping it on is more difficult than removing it. Because the grill of the .2 is angled (in comparison to a .1), you’ll notice that our U.S. plates now fill out more of the grill’s vertical height. Since you have to angle the carbonio unit (away from the grill) to get it on, our plates - with its size - can get in the way as the top side will rub against the car bumper. I have so far clipped it on by doing the attaching the carbonio first, then screwing on the plate. The other solution is to further extend the arms but then the plate will sit further out in front of the car.
Renewing an older thread because of a question I have.
Considering this product on my 991.2 GT3, but I'm concerned the grill will become marked or indented over time as this mount gets removed and reapplied from the same location.
Could anyone who's used it for a decent amount of time care to comment?
Actually any owners comments appreciated.
I have used the Carbonio for a couple months now for my .2 GT3. I have taken the plate on and off several times and have noticed that my insertion/placement has caused the paint to flake off the grill. IMO the flaking is caused by the plate's rubber pegs rubbing on the grill's metal as I rotate the plate's backing to place onto or remove it from the grill. I believe this problem would not be an issue had the grill not be painted but that's not the case. The unit so far has not dented the grill. I plan to use the Carbonio until the end of the track season when I'll purchase a new grill ($200+ part) and look for a tow-hook plate instead.
