Table size for engine drop
Hello Gents,
Setting everything in motion to drop my engine.
When I did my 3.2 aircooled I used a 24" x 28" table to drop it on and I was uncomfortable with it as I work by myself.
I want to build a table to drop my TT motor on using an engine stand that I will build up probably using 2" x 6" studs.
What is the best size table to make? 30" x 40" is the wheel spacing for my engine stand, but I could go bigger?
If you could do it all over again what size would you make? Height?
Thanks
Rod
Thanks
Rod
I should have mentioned that I have a lift, so I do not need a hydraulic table. Just a table.
i have a lift as well. the hyd table allows you to wheel the drive;ine out from under the car when its lifted off . then you can raise the table to comfortably work on the engine while sitting on a stool. it really does work well
30"x40" is lots of space.. your aircooled table would be fine too
Some of the reviews of the HF table claim it doesn't have a mechanical lock and it drops a bit when left overnight... HF often runs through several versions of their products so it's hard to tell if those flaws and complaints are on the current version or not. Anybody buy one fairly recently that can comment?
