996 Forum 1999-2005
Ticking comes and goes
Old 11-28-2017, 05:50 PM
tlakeusa
tlakeusa's Avatar
Default Ticking comes and goes
Right side ticking comes a bit after the car warms up after starting. It accelerates with revs. Turn it off and let it sit a bit and the process repeats. I have brought it to my Indie, awaiting his thoughts. Any thoughts here from this knowledgeable crew ?
thanks much
Old 11-28-2017, 06:26 PM
Chris(MA)
Chris(MA)'s Avatar
I think you'll get a bunch of advice about swapping oil. It might help and a cheap thing to try?
Perhaps try a stethoscope to pinpoint the location
Old 11-28-2017, 07:19 PM
tlakeusa
tlakeusa's Avatar
Thanks Chris , my Indie just chatted with me and says he can hear the tick top and bottom with stethoscope but having a hard time pinpointing. Definitely on the right side , left side quiet. Did JG last oil change. Just holding my wallet and hoping for the best. Saga continues
Old 11-28-2017, 07:33 PM
TonyTwoBags
TonyTwoBags's Avatar
By right side, you're taking passenger side? That's bank 2, where mechanical issues normally surface.
Old 11-28-2017, 07:34 PM
tlakeusa
tlakeusa's Avatar
Yes, passenger side
Old 11-28-2017, 07:38 PM
Ahsai
Ahsai's Avatar
Just upload a video or sound clip. So far, renn-diagnostic has been quite accurate.
Best case is sticky lifter and worst is bore scoring. Maybe you can try a can of seafoam in the crankcase and then change the oil and oil filter afterwards. What oil are you using?
Old 11-28-2017, 07:40 PM
tlakeusa
tlakeusa's Avatar
Using Joe Gibbs
Thx
Old 11-29-2017, 11:34 AM
Macster
Macster's Avatar
IIRC to use JG oil it is recommended (quite strongly I believe) some kind of "flush" is done first to remove any residual oil. (I did a quick search for info on this and was unable to find it, but I recall reading the process online here in fact.) Did you do that?
Old 11-29-2017, 10:12 PM
tlakeusa
tlakeusa's Avatar
All good on JG oil. BTW since last oil change only a shade over 1100 miles
Old 11-29-2017, 11:07 PM
turbogrill
turbogrill's Avatar
Too bad they don't have black friday in Germany, would be nice to stock pile on m96 engines...
Old 11-30-2017, 08:05 PM
tlakeusa
tlakeusa's Avatar
Valve cover off cant record, BTW run it up to 3k hold it and it goes away then slowly comes back at idle
Old 11-30-2017, 09:08 PM
Chris(MA)
Chris(MA)'s Avatar
Well that could point to a lifter which get pumped up more with oil at higher rpm?
What is your idle oil pressure?
Old 11-30-2017, 11:49 PM
tlakeusa
tlakeusa's Avatar
Pretty good overall , especially when thoroughly warmed up. Have been burning about a 1/2 quart plus t per thousand miles on average. I check by dip stick
Old 12-01-2017, 01:08 PM
AWDGuy
AWDGuy's Avatar
Post a video.
Old 12-01-2017, 06:48 PM
tlakeusa
tlakeusa's Avatar
It is on the rack and the tick is being hunted down as I type
Quick Reply: Ticking comes and goes
