993 Forum 1995-1998
Send Prayers
Old 10-18-2017, 11:30 AM
Cactus
Noodle Jr.
Cactus's Avatar
Default Send Prayers
The Cactuswagen is getting dropped off tonight for a new windshield
Old 10-18-2017, 11:47 AM
AOW162435
Seared
AOW162435's Avatar
Start drinking now.
Andreas
Old 10-18-2017, 11:59 AM
CarreraX
CarreraX's Avatar
I had a new one put in mine a few years ago (OE Porsche). I was there the whole time to make sure it was centered. I even made little spacer blocks to help him locate it. I lost way too much sleep beforehand and decided this was the best way. It turned out perfect BTW. Its critical so that your seals are located properly (as Im sure you know) . Also get pictures of the window channel showing there isnt any rust.
Brig993
Brig993's Avatar
I love my factory installed pitted windshield.
Old 10-18-2017, 12:00 PM
Mark in Baltimore
Mark in Baltimore's Avatar
Make sure your installer
Old 10-18-2017, 12:16 PM
AOW162435
Seared
AOW162435's Avatar
Andreas
Old 10-18-2017, 12:22 PM
M. Schneider
M. Schneider's Avatar
Originally Posted by AOW162435
Start drinking now.
Andreas
Start drinking ...H-E-A-V-I-L-Y ...
Old 10-18-2017, 12:23 PM
M. Schneider
I hear that !
Old 10-18-2017, 12:37 PM
goofballdeluxe
goofballdeluxe's Avatar
Originally Posted by M. Schneider
Start drinking ...H-E-A-V-E-L-Y ...
Looks like you already did
Old 10-18-2017, 01:08 PM
simpsoap
simpsoap's Avatar
When I had my windshield replaced, I knew and trusted the installer. We found some minimal rust damage, and addressed it all while the windsheild was out. I'd make sure you ask for pics if you can't be present when the windshield comes out.
-Soap
Old 10-18-2017, 01:19 PM
gt3'er
gt3'er's Avatar
I would definitely stay and watch. I would not let them install the outer seal (cover) prior to windshield install (they did on mine and therefore could not properly "center" the WS in the opening.) 90% of these guys are all about speed. And, you definitely want to see for yourself any potential rust.
You need a consistent gap all around, or the outer seal will not reach the painted surface, and will tend to fall in the gap. Also, they should not press the WS too far into the aperture or, again, the outer seal will not reach. Templates are available to confirm these things. You only get one shot to get it right. My installer would not touch it, even after I took it back and showed him the offset he created. Fortunately, after buying and returning 3 outer covers, I finally found one of the 2mm wider versions and it covers the gap.
Prayers are with you...
Old 10-18-2017, 01:28 PM
Cactus
Noodle Jr.
Cactus's Avatar
I did as well but the crack keeps spreading.
Old 10-18-2017, 01:29 PM
Cactus
Noodle Jr.
Cactus's Avatar
This is good stuff!
Old 10-18-2017, 01:37 PM
TJ993
TJ993's Avatar
dare I ask what this estimate will be
My rear channel cracked and found OE front avalable
Thinking of doing both at the same time but adding strut brace
Thoughts?
Best of Luck with a Steady Hand and Good Eye for Detailed workmanship!!
TJ
Old 10-18-2017, 01:41 PM
Cactus
Noodle Jr.
Cactus's Avatar
Guy has been doing local Porsche stuff privately and for the dealership approx 25 years so I am hopeful. I am running it through insurance and the glass is Pilkington.
Quick Reply: Send Prayers
