Laust vacuum manifold purge valve routing
Old 09-23-2017, 09:00 AM
Dan Martinic
Dan Martinic's Avatar
Default Laust vacuum manifold purge valve routing
I am now installing new Lindsey small vacuum lines using the Laust manifold (5 port).
Apologies if this has been covered: I am not sure how to run the purge valve line to the Laust manifold. That is, I don't yet know the function of the "bunny ears" part in between (see my pic).
What to do with this part?
What *is* the function of the bunny ears? A little hard to find on the PET for even a proper name!
Old 09-23-2017, 09:17 AM
MAGK944
MAGK944's Avatar
It's one of the emissions valves, it controls when fuel vapor is directed to the charcoal canister under the lh fender.
Old 09-24-2017, 08:51 AM
fejjj
fejjj's Avatar
Just bypass it and go directly to the TB.
Quick Reply: Laust vacuum manifold purge valve routing
