ERROR CODE 34 HALL SENSOR....
Formerly turbotwoshoes
Spent the last four months taking my time and working on my car. I did a complete rebuild on my suspension, set valves, new vale covers, fuel pressure regulator, etc. Started the car and within a minute it idled our smoothly as always. My problem is that when hot or cold, it does not pull hard like it used to . It seems to be hesitant and missing as it climbs through the rev range. Noticeable from 3K RPM's and up to 6K. I hooked the Durametric up and the only error codes I received were ? Module one error and the #34 Hall Sensor error which remained on the entire time (1+ hour I was trouble shooting.) What are your suggestions on trouble shooting this problem? Thanks, Jack
I ran the Durametric on my car(no problems, just checking) and got the #34 Hall sensor code.
You obliviously have a problem. Guess you could swap the sensor with one from another car,
and see if that corrects the problem. I read Laker's link, so maybe I am missing some acceleration? Car feels fine though.
