OEM Widebody Side Skirts on a C2S
This is a topic that has been discussed numerous times and the consensus is generally that the OEM side skirts will not work on a narrow body 911. However, the material is very pliable, so I figured it was worth a shot.
After spending some time with them, I can finally give everyone a decisive answer: It is possible
I spent about an hour with a dremel carefully removing the bits that prevent it from sitting flush on the narrow body frame. This was all very elementary work. I have modified them to screw into factory locations, and will use a light 3M adhesive on the outer lip. I still have to go over the fine details to make everything sit perfectly, but I could not wait to share some photos of the beginning stages.
I will be posting a comprehensive DIY as I complete the other side of the car.
*Please note that these are not installed photos, I just have them held up to the car.
The following 2 users liked this post by gbree:
AdamSanta85 (09-01-2019),
Zuffenhoser (11-01-2021)
Very cool! Look forward to finished pics.
Thanks, guys! The only reason I am not finished is because I am still trying to decide whether I should use trim lock or 3M VHB tape on the upper lip to attach it to the body.
Are there any hidden holes under a narrow body car that could be used for the OEM fasteners?
You sir win the gold star for the day. I've been waiting nearly a year for someone to try this, and you did it! Looks like I'll be ordering me a pair from suncoast.
Narrow body has a fastener on each end. I believe wide bodies have them in the middle part too? Either way, use automotive double sided tape in the middle and will be fine.
I have successfully mounted to the bottom of the car using OEM locations. I am just trying to decide the cleanest way to shave down the upper lip a bit more in order to make everything perfectly flush. Once I complete that, I will run some 3M tape along it and it will be done.
I guess I will go ahead and order a set now since I know it can be done
