964 Forum 1989-1994
finally, sunroof delete, RS carpets, rear reflector and more
Old 09-03-2017, 05:33 PM
kos11-12
kos11-12's Avatar
Default finally, sunroof delete, RS carpets, rear reflector and more
Hi guys ,
I finally decided to delete my sunroof and do some more paint work and repairs, I am also fitting RS carpets, removing the sound proof but replacing the rear by some modern and light sound proof & heat mats, at the same time I am deleting the glove box, knee panel and also the center console,
I also finally fit replace my rear reflector with the grill made by Andrew.
i also fitted the C4 front drop links from éléphant racing.
Old 09-03-2017, 08:02 PM
964Andrew
964Andrew's Avatar
Looking great! Good luck with all time worst nemesis - gorilla snot glue.
Thanks!
Andrew
Old 09-04-2017, 03:27 AM
HiWind
HiWind's Avatar
good going K! How did you weld/fix the SR delete? Was it the fennlane one?
Old 09-04-2017, 05:24 AM
kos11-12
kos11-12's Avatar
Hi , yes I bough a kit from Fennlane , steel panel, roof foam , perforated lining and 2 steel rods,
apparently the panel needed some mods they cut the folding edge , but that was a bit expected....
I was going to delete the gutters but it is quite expensive , I couldn't justify the cost ....
still thinking about the plexiglass rear and 1/4 window from DP. Need to quickly decide.
Andrew , the grill looks great , cheers
Old 09-04-2017, 01:38 PM
Spyerx
Spyerx's Avatar
Received 1,730 Likes on 1,058 Posts
What roof foam did you use?
Pics of finished inside?
I'm doing this as we speak. Bought oem perforated liner and the steel bows and bits already.
Old 09-04-2017, 01:47 PM
Catorce
Catorce's Avatar
Nice car dude!
Old 09-04-2017, 04:23 PM
kos11-12
kos11-12's Avatar
hi ,
appatently the foam is to be able to make a good fit .
When you removed the perforated lining did you notice the foam ? It's a special one I suppose you can buy it from Porsche , I suggest you give a ring
to Chris st Fennlane in UK .
sorry no pictures yet, it's not finished,
I saw you pics your panel looks good !
Old 09-04-2017, 08:30 PM
Spyerx
Spyerx's Avatar
I need to talk to my shop. I didn't remove anything they did. The sunroof liner came out nicely though. I just don't know what was under it. I've been traveling too much for work to drop by during the process....
Old 09-04-2017, 10:19 PM
Jjm4life
Jjm4life's Avatar
Do it. Very happy with mine. No issues with discoloration or distortion, both of which I was warned about.
Old 09-05-2017, 03:27 AM
kos11-12
kos11-12's Avatar
hi there,
the windows are out , if I do it later it will be a twice the job,
would you have pictures of yours , thanks
Old 09-05-2017, 04:04 AM
kos11-12
kos11-12's Avatar
are you living in a hot climat location
cheers
Old 09-05-2017, 10:39 AM
Jjm4life
Jjm4life's Avatar
Boston Ma. I'll try to get a few pics today
Old 09-05-2017, 01:01 PM
911Jetta
911Jetta's Avatar
...I am deleting the glove box, knee panel and also the center console...
Great project! Looking forward to seeing how you center console delete turns out.
Old 09-05-2017, 02:50 PM
kos11-12
kos11-12's Avatar
Cheers !
inspired by Rob64 interior,
it is quite tricky to hide everything nicely ,
will post pictures when done
Old 09-05-2017, 02:53 PM
kos11-12
kos11-12's Avatar
Trying to find out if I can tinted those window,
it make a difference when the sun is out .
Quick Reply: finally, sunroof delete, RS carpets, rear reflector and more
