Weight reduction ideas
Old 08-18-2017, 08:29 PM
Cloud9...68
Cloud9...68's Avatar
Default Weight reduction ideas
I know a ton has been posted on this topic, but the information is scattered through many threads, making the search I attempted less than fruitful, so I thought I'd start a new 944/968 specific thread. Mine is a track-focused 968. I drive it to and from the track, so it has to remain street legal. I don't want to remove the carpet, or the door panels at this time. Here's what I've done so far to take weight out of it:
-Sparco Evo drivers seat, some sort of Corbeau fixed-back fiberglass racing seat on the passenger side that I bought used
- Fiberglass hood, with aluminum louvers. Removed struts, but kept hinges and latches. I'm guessing total of 10-15 lb savings
- 4 lb Battery Tender lithium ion phosphate battery
- Fixed headlights (featherweight Hella bi-halogens) ~30 lb savings
- Removed front bumper bar - 15 lb savings
- Removed fog lights, and replaced with fiberglass brake duct scoops
- Removed rear bumper bar - 20 lb savings
- Removed windshield washer reservoir - 12 lb savings
- Removed cruise control
- Removed passenger side air bag and control module
- Removed the surprisingly heavy eyelets that I think were used to strap the car down on the boat ride from Germany
- Converted electric sunroof to manual
- Removed stereo and speakers (almost always drive with the sunroof off, so I can't hear it, anyway) - Saved about 12 lbs
- Removed AC compressor, radiator, drier, and assorted plumbing. Built my own brackets to relocate the alternator to the A/C compressor’s spot – Saved about 25 lb.
- Removed fuel rail cover
- Removed rear seat
- Removed rear quarter interior panels, cargo area carpet and pad
- Removed rear window wiper and motor
- Removed hatch opener motor (converted to manual operation)
- Removed spare tire, jack, and tools
- Replaced stock exhaust with RS Barn cat back
- Single-mass aluminum flywheel – 17 lb, I believe
It has a weld-in roll bar/half cage from Hanskville Hotrods, which adds back about 30 lbs, iirc, along with a harness (drivers side only), in addition to standard inertia reel seat belts I bought off eBay. It also has Racers Edge heavy duty A-arms, which add several pounds back as well. I know a lot of people on this forum track their cars, so I was wondering if there are any opportunities I've missed. I think I'm reaching the point of diminishing returns in terms of cost/benefit, but I'm curious as to other peoples' ideas. Obvious things I haven't done yet include a plexiglass hatch window, a proper racing steering wheel, a lighter alternator, and a lighter passenger seat. Anything else?
Old 08-18-2017, 09:44 PM
951and944S
951and944S's Avatar
- Removed rear seat
Go lexan on the back deck glass. If done right (with a center brace) you'll never miss the glass.
If you ever had a complete door off and carried one fully loaded just 20 feet, then picked up a gutted door, you'd see where the real weight is. We don't run windows at all (all track and tow with trailer) but you could make some tracks and do manual raise/lower lexan on those for street.
Other than that, pull your fender and scrape all the sound deadening, while they are off, pull the fender liner and do the same on the whole wheel house.
T
Old 08-18-2017, 10:08 PM
sm
sm's Avatar
Cloud,
What's your car weigh now?
Old 08-18-2017, 10:26 PM
sm
sm's Avatar
Regarding the hatch, has anyone used Percy's Speedglass for the 944/968 hatch? I hear great things about their lexan, but can't find someone who's used it for the hatch on these cars.
Old 08-19-2017, 12:08 AM
V2Rocket
Rainman
V2Rocket's Avatar
FWIW the stock glass rear hatch with rubber spoiler is 52 lbs.
Lexan should be about half that.
Old 08-19-2017, 01:26 AM
rlm328
rlm328's Avatar
Fiberglass hood
Fiberglass front fenders
As stated by you Lexan rear window
Side quarter windows Lexan
Excess wiring harness
If you want to retain your carpet (fire hazard), temporarily remove it to get at all the sound deadening material under it.
You need the front metal bumper bar for tow ring attachment. Drill it for weight savings.
Old 08-19-2017, 01:37 AM
rlm328
rlm328's Avatar
Here is an old weight reduction list I found. Please note I am not the author, though I wish I were.
File Type: doc
Old 08-19-2017, 07:57 AM
PorscheFanatic202
PorscheFanatic202's Avatar
T
Just got a full door... they are stupid heavy. I was surprised. I'll weigh mine today for a reference.
Old 08-19-2017, 12:26 PM
Noahs944
Noahs944's Avatar
I completely agree the doors are pigs.
I have converted to a strap with holes rather than the motors. Still running glass. One thing I'd be concerned with is scratching the lexan on the weatherstrip, so for myself this wouldn't be idea. I have realized if don't correctly I can pop the glass out very quickly for track use if I must. But I don't knot what the best solution is. Right now I'm considering sliding windows in lexan. Do most racing sanctioning bodies allow for these?
Old 08-19-2017, 12:42 PM
Noahs944
Noahs944's Avatar
Cloud,
Imho the weightlose concept is a double edged sword. In my 944, all steel and all glass. Street legal with a/c retained. Weight measurement was 2500lbs with one seat & half a tank. That was like 2 years ago. I was proud, but later feel embarrassed by certain choices I made (some which I can't undo).
In a daily driven cars sometimes we go to far.
Food for thought: You have a roll bar (nice start)
In a rollover your doors & windows play a HUGE part in supporting the roof front collapsing. The rollbar isn't going to save your neck or back in a rollover; it really isn't much more than a shoulder harness mount. I know because I also have the Hanksville roll bar and have assessed this critically. My advice is to retain glass & either manual or electric window regulators until you install the rest of the Rollcage. The reason being at this point the Porsche body as a unit -with glass up) is what is will protect you from injury until you go full cage.
Old 08-19-2017, 12:56 PM
Cloud9...68
Originally Posted by sm
Cloud,
Unfortunately, I didn't weigh everything I took off the car, but my guess is around 2800-2850 pounds.
Old 08-19-2017, 01:01 PM
Cloud9...68
Actually, I built a tow hook mount that I attached to the original mounting points for the bumper bar. It works great - have had to have the car towed a few times.
Also, thanks for the weight reduction list. I can verify that many of the figures in the list are accurate. However, some, like the bumper bars and hood, which I weighed, are way off. I think the person who compiled the list put the weight in pounds in the kg column on some of the items, and then erroneously multiplied this number by 2.2 to come up with the figure on the lbs column.
Old 08-19-2017, 01:23 PM
Cloud9...68
Originally Posted by Noahs944
Cloud,
Nicely thought out and well put. Yes, safety always has to come first. Also, it's important to keep things in perspective. I just use the car for sessions at the local driving academy. I look at it as a training tool for my ultimate goal, which is to participate in an arrive-and-driver series (when my kids are out of college) like the Simraceway series at Sonoma International Raceway. I just want to strike a balance between a car that is capable, responsive, and can pass other cars at least as often as it gets passed (there's a lot of high dollar hardware at Driveway Austin), without costing a fortune to run. At this point, I'm just looking for any items that I may have forgotten about. The lexan rear hatch and a lighter passenger seat may be the next, and possibly the last, things I do in the weight reduction department. Unless my friend with the trick Miata adds a turbo - then it's game on
Old 08-19-2017, 01:49 PM
Humboldtgrin
Humboldtgrin's Avatar
I didn't see the list but it's probably for a 944 not a 968 so the 968 hood is probably a lot lighter in stock form. My 944 stock hoods are heavy and my fiberglass hood is supper light compaired.
Old 08-19-2017, 01:58 PM
V2Rocket
Rainman
V2Rocket's Avatar
i think i weighed a stock 944 hood at around 42 lbs once upon a time.
Quick Reply: Weight reduction ideas
