MOTEC Harness and parts for 996
Category: Engine - Electrical
Price (no $ sign please): $3000
Location (Region): SoCAl
Item Condition: Used
List below of parts - some pictures of them as well. If you need more specific info please email me revogvw@gmail.com
$3000.00 takes the whole lot.
Located in SOCAL (Long Beach, CA)
Jason 714-699-3676
996 Hurricane parts
ITEM QTY NEW/USED S/N
MoTeC DBW4 1 NEW 14011-00380
Sakata Level5 996 Hurricane engine/ign harness 1 USED
Sakata Level5 996 Hurricane e888 harness 1 USED 1206-27C/4642
Sakata Level5 996 Hurricane ecu/chassis harness 1 NEW 1208-30A/4664
Sakata Level5 996 Hurricame ignitor harness 1 NEW 1208-30C/4666
Sakata Ignition Box 1 NEW 1208-31W/4667
997.351.959.91 – 997 GT3 Brembo Pistons 8 NEW
996.572.311.00 – Splash Protection 2 NEW
MoTeC M DHALL 437-DTM differential hall sensor 1 NEW
MoTeC BR2 – Beacon Reciever 1 USED 0413
997.583.111.90 - Krontec Air Jack – 997 GT3 RSR 1 NEW 13486
996.110.101.BR – 996 GT3 Intake Manifold lower 2 NEW
993.110.199.00 – 5bar fuel pressure bypass 2 NEW
997.602.104.02/1 – Beru ignition coils 6 USED
993.637.049.02 – Immobilizer Key Fob 1 NEW
Internal Gate Actuators w/ oil drain reservoir 2 USED
Drive Flange 2 USED
Differential (OEM open) 1 USED
AP Racing – CP6465-212 – master cylinder 1 NEW
996.123.216.74 – heatshield 2 NEW
44036 – IVM Autosport 996 GT3 RSR Folding to hook 1 NEW
996.505.019.9B – mount for tow hook (no hook) 1 NEW
996.207.212.70 – oil level sender flange custom – GT3 1 NEW
996.375.315.05 - ? 1 USED
996.01 - ? - Looks like cogged belt drive flange/gear 2 NEW
996 GT3 RSR Power steering connector 3 NEW
misc brackets / turbo supports USED
996.559.501.00 – flap 3 NEW
996.105.109.0R – flange 1 NEW
900.378.139.01 – bolt 1 NEW
996.105.139.09 – coolant flange 1 USED
996.107.319.90 – 996 GT3 Support 1 USED
997.347.455.9B – gt3 Press Hose 2 NEW
996.110.630.75 – gt2 turbo press hose 1 NEW
large worm clamps with quick release 2 NEW
Kit of clamps and o-rings for charge pipe push fit 1 NEW
996.106.477.78 – hose 1 NEW
996.106.546.55 – water hose 2 NEW
996.110.631.74 – charge hose 2 NEW
997.347.555.90 – gt3 return line 2 NEW
997.347.545.90 – gt3 line 1 NEW
915.300.911.01 – elring gasket set 1 NEW
996.423.019.04 – throttle pedal 1 NEW
DBW throttle body – Bosch 1 USED
996.106.628.76 – water hose 1 NEW
996.106.638.76 – water hose 1 NEW
997.505.682.01 – strut 2 NEW
997.505.681.01 – strut 2 NEW
997.624.105.01 – wiper motor Bosch 1 NEW
996.604.107.02 – starter 2 USED
OEM 'hockey puck' horn button 911/912 1 USED
CPN-3938 – ring sets 100.00/1.00/1.20/2.86 6 NEW
996.341.322.71 – gt3 speed cable support 1 NEW
999.707.164.40 – o-ring 1 NEW
CNC mount/clamp 1 USED
Conti-519.0036.00 – oil hose 1 NEW
996.207.160.70 – oil tank fill tube 1 NEW
996.110.646.2R – gt2 Y-pipe w/TMAP 1 USED
996.106.730.71 – water tube 1 NEW
conti 6pk1153 – belt 1 NEW
conti 6k1120 – belt 1 NEW
bando 6pk1105 – belt 1 NEW
6pk1162 – belt 1 NEW
996.102.161.9A – belt 2 NEW
996.102.151.9A – belt 1 NEW
misc stainless turbine inlet gaskets 4 NEW
999.707.455.40 – o-ring 3 NEW
999.230.541.10 – clutch pipe union 3 NEW
Sachs Racing 88 3182 99B 538 – release bearing 1 USED
997.505.317.00 – bumper plate 1 NEW
996.504.715.00 – grommet NEW
996.106.509.71 – gt2 turbo support 1 NEW
999.507.657.09 – plastic nuts NEW
997.511.551.01 – hood shock 2 NEW
996.105.412.51 – mounting 1 USED
996.106.417.51 – water line support 1 NEW
999.507.487.40 – fuel line support 1 NEW
996.606.236.91 – gt3 shield 1 NEW
997.347.235.9A – 2mm spacer 4 NEW
997.347.235.9B – 4mm spacer 6 NEW
964.356.635.00 – rubber grommet NEW
996.111.217.70 – gt2 turbo gasket 2 NEW
996.111.215.70 – gt2 turbo gasket 2 NEW
996.106.802.11 – retaining spring NEW
996.106.405.71 – coolant expansion support 1 NEW
997.347.235.9B – spacer ring 4 NEW
986.606.136.00 – shield 1 NEW
991.106.913.52 – water hose support 1 NEW
999.511.237.40 – hose support 1 NEW
997.606.109.90 – gt3 steer angle sensor gear 1 NEW
996.106.417.73 – water hose support 1 NEW
996.106.525.04 – cooling line support 1 NEW
997.347.587.90 – grommet 2 NEW
996.341.322.71 – abs cable 1 NEW
997.512.551.00 – rear lid gas spring 1 NEW
997.424.040.90 – 997 cup car shift cable 1 USED
alcohol injection system pump – DDP5800 1 NEW
aquamist jet 0.5mm 6 NEW
aquamist jet 0.6mm 6 NEW
aquamist jet 0.7mm 6 NEW
aquamist jet 0.9mm 6 NEW
water injection diverter valve – needs o-ring 1 USED
water injection diverter valve 1 NEW
box of misc silicone charge hoses 1 NEW/USED
several parts that I have no idea what the **** they are NEW
misc stainless lines w/banjo 6 NEW 996 gt3 fuel rails (L+R) w/ -8 AN adapters & 5bar bypass – water pipe
