996 Turbo Forum 1999-2005
best high bite brake pad for stock system?
Old 07-20-2017, 07:48 PM
garrett376
garrett376's Avatar
Question best high bite brake pad for stock system?
Hi Guys,
My 996 turbo, as well as my prior 03 C4S that shares the brake system, has always had a disappointing level of bite when braking compared to my 02 Carrera. I feel I need to stand on the pedal to get to stop hard, unlike my 02 Carrera model. It seems like they designed this system to have a significant amount of modulation to permit smooth slowing of the car which I don't prefer. I want it more aggressive.
On my turbo and C4S I've tried stock pads and Stoptech Street pads, but they both lack the bite that I want. Has anyone tried any other STREET pad that can significantly increase the bite so it is far more aggressive? Cool carbons? Hawk? Carbotech? Cobalt Friction? The 996 Carrera brakes feel so much better... so do the Cayennes!
If pads can't do it, can larger diameter rotors do it? Or is this only achieved with a GT3 type caliper up front with larger rotor in the rear?
Thanks for any suggestions or info about your experiences.
Old 07-20-2017, 10:02 PM
mpsig226
mpsig226's Avatar
Some insight right up your alley !
https://www.renntech.org/forums/tuto...hs-and-truths/
Old 07-21-2017, 03:14 AM
911mhawk
911mhawk's Avatar
When you say high bite, are you meaning on the street when pads are often cold, or at the track after several hard laps?
A recommendation requires your intended use of the car.
I found with stock brakes on the street, Textar/OE with fresh Motul RBF600 had pretty quick bite.
On the track, the 380/350 combo with PFC 11/8 will get you down from 150 to 80 pretty instantly and don't fade.
The pedal in our cars does require more effort and may also travel more than many other sports cars I've driven but I like the modulation that allows. Ride a road bike a ton so it quits bugging you
Old 07-21-2017, 08:14 AM
mxracer
mxracer's Avatar
These do well for me on the street. I had the dame feeling as the OP. Bonus is these pads don't throw a lot of dust.
Hawk HPS Pads
Front HB667F.622
Rear HB550F.634
Old 07-21-2017, 01:01 PM
garrett376
garrett376's Avatar
Thanks guys. As I tried to state above, this is for the street only, and the stock system.
I am hoping someone feels the same as I (not enough bite), and has tried some pads I have not yet to save me from burning $$ trying to find the highest biting street pad. Based on StopTech's info, I thought they'd fit the bill but all they do is decrease dust over stock textar/pagids with no change in initial bite/torque.
MXRACER, I have never tried Hawk pads, thanks for that info!
Old 07-21-2017, 01:16 PM
mxracer
mxracer's Avatar
NP.. One more thing I should add if you end up with the Hawk pads. Bed-in time is long compared to stock, but once bedded in they work really well.
Old 07-21-2017, 08:44 PM
Mtrboatvr6
Mtrboatvr6's Avatar
I went with PFC 8/11's at the recommendation of people on here. Feels like a completely different braking system. Amazing bite, no fade, and INCREDIBLE stopping power. They transformed the car. Worth the school bus brake noise when Im driving to the track. The OE Textar pads are ok, but I much perfer the PFCs for doing any kind of aggressive driving. Im also running fresh Motul 660 fluid.
RennKit-Dave (06-04-2021)
Old 07-21-2017, 10:50 PM
powdrhound
powdrhound's Avatar
Received 1,719 Likes on 1,001 Posts
Adding the OEM 997 engine cam driven vacuum pump greatly increased the "bite" of the brakes on my car. Night and day..
Old 07-22-2017, 01:33 AM
highlander
highlander's Avatar
I was also a little taken aback by how little bite there is in the braking system. Especially compared to my '0S 987s.
When I took delivery of my '02TT, one of the first things I did was replace the worn disks and pads with OEM rotors and EBC Red Stuff pads. I had the EBC's on my old '01 986S and quite liked them. On the 996TT however, they are junk. Heavy dust and no bite whatsoever.
I might try the PFC's when it's time for new pads, but I have heard that they are a wee bit loud.
Old 07-22-2017, 01:38 AM
garrett376
garrett376's Avatar
That's very interesting... so is this an assist issue?
I run PFC's on my C2 race car and don't want them on a street car.
Old 07-22-2017, 03:31 AM
garrett376
garrett376's Avatar
I thought about this more... the C4S has the 996 carrera vacuum draw so the manifold vacuum itself shouldn't affect the feel... Maybe the booster is different on the Carrera vs. turbo...
Old 07-23-2017, 02:42 PM
Mtrboatvr6
Mtrboatvr6's Avatar
Correct, they are loud, but they are incredible. The squeal is worth the performance.
Old 07-23-2017, 03:25 PM
powdrhound
powdrhound's Avatar
PFC is a full on race pad designed for optimum performance at temperatures that you will never be able to attain on the street. They do have good bite when cold at the expense of being very very abrasive to the rotors. If you're running a street car, it's the wrong weapon for the fight. For a street car the Endless MX20 is a great pad but not cheap at about $700-800 for the set.
Old 07-24-2017, 07:41 AM
DaveCarrera4
DaveCarrera4's Avatar
Here is a suggestion, I ran the Pagid RS black pads, street and track, low dust, no squeal. Very good bite. Have moved on since the 6 turbo is only used at the track.
Old 04-12-2019, 09:18 AM
BMiller33
BMiller33's Avatar
You got a PN for that bad boy?
Quick Reply: best high bite brake pad for stock system?
