Parts Search
Keyword:
Category:
Price (no $ sign please):
Private or Vendor Listing:
Location (Region):
Item Condition:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Cont. Porsche Models:
Color:
Private or Dealer Listing:
Location (Region):
Transmission Type:
COMPLETE 1987 Porsche 944 S 2.5 16V DOHC ENGINE M44-40 REBUILT/RESEALED
Old 04-12-2014, 06:30 PM
yellowline
Under the Radar
yellowline's Avatar
Default COMPLETE 1987 Porsche 944 S 2.5 16V DOHC ENGINE M44-40 REBUILT/RESEALED
Category: Engine - Complete
Price (no $ sign please): $1200
Part fits (select ONLY those which apply): 924/931/944/951/968
Location (Region): NorthEast
Item Condition: Used
For sale is a 1987 Porsche 944S 16V 944S Engine - Great Track Engine - Highest Reving (6800 RPM!) Stock 944 Engine (190HP/170FTLBS) - $1,200 OBO
Everything was done EXCEPT FOR THE RINGS AND MAIN BEARINGS (Completely resealed / new valve stem seals / head is straight).
-New timing chain AND pads
-New Metal J tube with new copper crush washers
-Lindsey racing oil pan baffle
-Cleaned/flow tested fuel injectors - (sent to Witchhunter Performance)
-Painted valve cover (Black POR15 high temp paint was used)
-New clutch componentry (Everything minus the Pressure Plate/Clutch/Throwout bearing). New Needlebearings, guide tube.
-New Rennbay copper exhaust manifold nuts. - exhaust manifold is attached
-The Engine comes with the DME/Intake/Exhaust Manifold/AFM. The intake manifold is NOT attached.
Things that it needs:
-Two or three new rollers (all of the other rollers are new!)
-New Timing/Balance Shaft belt (the belts are new, but the engine sat in a shop for two years...New TB/BS is on there but I would still change it due to age)
-New Oil Pressure Sending unit (current one has a stud that is broken)
More Information:
- One of the intake manifold lines crumbled when the engine was taken apart. I would change them all anyways if you have the engine out.
- Engine wiring harness is a little worn but is still usable.
- The engine was rebuilt and intended to be put back into a project car. The engine sat in its current state for about two years in a shop. All of the ports were closed but the outside of the block is a little dusty.
- I can easily do a compression and a leakdown test under request.
- Engine had ~130,000 Miles prior to rebuild
Pickup only - engine is located in Northeastern CT. Again, this comes with the intake manifold, oil dipstick tube, exhaust manifold, wiring harness, DME and AFM, all covers, all stock pulleys, distributor +wires, and the Alternator bracket. Many of these things are not shown in the pictures For a little bit extra, I will gladly include the 16V airbox and semi-rebuilt alternator (new voltage regulator!).
yellowline is offline
Old 06-23-2014, 08:48 AM
Fronkenstein
Fronkenstein's Avatar
Still available?
Fronkenstein is offline
Quick Reply: COMPLETE 1987 Porsche 944 S 2.5 16V DOHC ENGINE M44-40 REBUILT/RESEALED
