Parts Search
Keyword:
Category:
Price (no $ sign please):
Private or Vendor Listing:
Location (Region):
Item Condition:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Cont. Porsche Models:
Color:
Private or Dealer Listing:
Location (Region):
Transmission Type:
Porsche 3.0 968 Engine for sale
Old 08-03-2018, 04:28 PM
968#33's Avatar
Default SOLD - Porsche 3.0 968 Engine for sale
Category: Engine - Complete
Price (no $ sign please): $2000
Part fits (select ONLY those which apply): 924/931/944/951/968
Location (Region): SouthEast
Item Condition: Used
3.0 968 engine
3.0 968 engine
Complete 1992 968 3.0 liter engine, came with 6spd manual transaxle. Transaxle NOT included.
INCLUDED: ECU, injectors, power steering pump, alternator, A/C compressor, wiring harness, OEM cat back exhaust, headers
Not Included: Clutch housing
What you will need: Clutch housing, new pressure plate, clutch, clutch release lever. Engine needs a refresh. Cams are in great shape, all teeth are there for cam chain. I would recommend new cam chain/cam chain pad, all new gaskets as engine leaked oil from many places. Knock sensors/speed sensor IS there, but I would replace with new with engine refresh. USED the past 6 years as track car only....never left me stranded on track.
$2,000 Located in Charlotte NC area. Can arrange to deliver within 300 miles....
Thanks...
Jerry sends...
Semper Fi!
968#33 is offline
Old 08-03-2018, 11:02 PM
KEVIN ANDERSON
KEVIN ANDERSON's Avatar
Great price! The crank alone is almost worth that price
KEVIN ANDERSON is offline
Old 08-04-2018, 12:05 AM
968#33's Avatar
Absolutely true! Basically giving it away at 2k. PLUS OEM exhaust (unless somebody wants it alone).
Also: NO MAF or Airbox....these are not included.
968#33 is offline
Old 08-04-2018, 09:26 AM
968#33's Avatar
Good point Kevin; even the CAMS alone are almost 2k......you can't buy a complete head for 2k....
Somebody.....somewhere, interested in taking this extra engine off my hands.
No internal damage, cams/chain/teeth are 100% fine; balance shafts are there, water pump...all with exception of items noted above.
968#33 is offline
Old 08-04-2018, 07:57 PM
968#33's Avatar
Bump....
968#33 is offline
Old 08-07-2018, 01:42 PM
968#33's Avatar
I ran this engine on TRACK ONLY from 2012-2017; Ran fine when I removed it and did the engine swap. Reason I swapped out was that I ran through 1.5 quarts of oil PER TRACK DAY...and it still had original flywheel, street clutch. I wanted to do upgrades like balance shaft delete, lightweight flywheel, etc..... So I found an engine that a good friend of mine built for a mutual buddy...with all of the things I wanted to do and bought it and swapped. Now I have this OEM original engine for sale.
This engine is complete, BUT I would rebuild it/refresh it for use. If you have it out...you SHOULD do that; for leaks alone. Just wanted to make sure everyone knew of that.
968#33 is offline
Old 08-09-2018, 11:13 AM
968#33's Avatar
968#33 is offline
Old 08-14-2018, 10:53 PM
968#33's Avatar
This engine is no longer for sale. Thanks...
968#33 is offline
Quick Reply: Porsche 3.0 968 Engine for sale
