Mark this thread as Sold
Parts Search
Keyword:
Category:
Price (no $ sign please):
Private or Vendor Listing:
Location (Region):
Item Condition:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Cont. Porsche Models:
Color:
Private or Dealer Listing:
Location (Region):
Transmission Type:
Custom 4L 996/997TT engine by Performance Development
Old 09-04-2016, 09:17 PM
310JAY
310JAY's Avatar
Default Custom 4L 996/997TT engine by Performance Development
Category: Engine - Complete
Price (no $ sign please): $46000
Part fits (select ONLY those which apply): 996, 997
Location (Region): SoCAl
Item Condition: Used
Offered for sale is a Performance Developments custom built Porsche 996/997 Twin Turbo 4 Liter engine in Calibration with ESMOTOR building the Billet Intake manifold. Engine is blueprinted and ready for delivery. The timing is set and it is ready to drop into any Porsche 996/997 Twin turbo. This engine was built to hold 1500Hp and anything less would just make it bullet proof. The engine is engineered to meet the power expectations with a some
element of reliability. Power levels and use along with tuning can change
the reliability and life expectancy of any engine. 1000+ HP is a serious
engine and requires parts suitable for obtaining this level along with user
care. An engine is the sum of its parts.
The parts included in the list are our 4.0L Turbo builds. These
engines produce 830+WHP at 0.9B manifold pressure.
A few words about the builder. Performance Developments and Engine Design was founded in 1990 by Neil Harvey. Neil has been in the industry since 1973, which is why we are a leader in prototype engine design and development with a reputation for quality engine rebuilding. Neil Harvey brings unparalleled credentials and experience, which include Formula 1, Cart, Sports Cars, GT, SCCA Pro Racing and SCORE off road. As a member of a team with 2 Formula 1 world championships, 1981 and 1983, Neil gained impressive knowledge of design and the requirements for winning. This is why customers worldwide trust Performance Developments with their engines.
The cost of this engine to replicate would be near $85K for PD to replicate not counting the case itself and ESMOTOR intake etc. I have receipts which includes labor charges and the following: Prep Case for windage. Machine case for piston skirt clearance Machine case for stepped head studs Machine galley plugs and fit to case Machine heads for custom sealing system Machine cam trays for high lift cams Machine cylinder heads for stepped washers. Machine piston valve pockets for high lift cams Mock up engine with new rods and gt3 oil pump Disassemble engine, intake system, go through parts labor fit lower manifolds and injectors, go through water plumbing, start final fit of new manifold. Intake manifold fitting, assemble engine. Engine can be picked up in Porter Ranch Ca or can help arrange freight shipping on buyers expense.
$46K is a steal at more then half off and no down time. This is a complete motor with the best internals money can buy including the best intake manifold from ESMOTOR and harmonic balancer.
Reasonable offers welcomed!
Here is a complete list of what is included with the engine:
-4 Liter 102.00mm Custom Pistons with Steel Cylinders
-Billet 82.00mm 4L Crankshaft with direct oiling to the Rods
-Arrow Precision Connecting Rods with Clevite steel backed Tri metal Rod bearings
-Performance Developments CNC ported Cyl heads
-Long stem Intake Valves for Flat Cam followers
-Performance Development Race Valve springs Titanium Retainers
-ARP Custom 12.00mm Head studs
Custom designed by Performance Development
Custom thread depth and threads
-Custom Performance Development flat cams (high lift) Race variable cams
Designed and manufactured by Performance Developments with zero harmonic distortion.
-Brand New GT3 Oil Pump
-ATI Crankshaft Harmonic Balancer:
http://performancedevelopments.com/p...enginefailure/
-Custom Performance Developments head sealing system:
Sealing System – The dual ring system for the 996 and 997 Turbo engines use our proprietary Back up Ring along with custom Head Gaskets made especially for this system. A gas filled Garlock Ring is used to seal the Cylinder gases.
-All Coolant lines Welded
-ESMOTORS Intake Manifold with Custom GT3 throttle body including lower runners which have been balanced:
http://www.esmotor.com.tr/product/po...-manifold-kit/
Custom ESMOTOR GT3 Throttle body with O-ring for tighter seal
Accept payment by Wire, Check, and Cash in Person. If you have any questions please do not hesitate to contact me.
310JAY is offline
Old 09-05-2016, 12:00 PM
RajuPatel
RajuPatel's Avatar
hi, i have a 2007 997.1 Turbo TT. I have just upgraded the VGT from Emre. The engine has run 30,000 kms in all and hardly 500kms after the turbo upgrade. Would you consider a swap? If yes, then about the map tune? What would it cost shipped to NY 11416?
RajuPatel is offline
Old 09-06-2016, 04:26 PM
310JAY
310JAY's Avatar
Not sure if I understand your question. If you are asking if I will directly swap your stock 997tt engine with low miles to a fully built 1500hp capable engine with no miles then I will pass but thanks for offer. If you would add cash to the deal then you can pm me the details.
310JAY is offline
Old 09-08-2016, 07:56 AM
RajuPatel
RajuPatel's Avatar
Of course there would be a cash involved. the question is how much would you want after the swap?
Old 09-11-2016, 02:19 PM
310JAY
310JAY's Avatar
Responded to all pm's.
I will post this to clarify a few things as the few pm's were asking the same thing. This is a fully built motor with 0 miles. I got it back 5 months ago. It has never been ran. No turbos or fuel system come with it, as this is best configured by the end user.
This built took a very long time and as you can imagine very stressful but I feel it will make someone that wants to make a lot of power very happy and no 1 year down time due to parts, life etc..
I also got a few people wanting to trade in their motor's plus cash that I was considering but no longer. Thanks for looking.
310JAY is offline
Old 09-13-2016, 11:41 PM
310JAY
310JAY's Avatar
A few more pm's responded to regarding different fitment on different applications. It will be able to run stock ECU on 996tt but in order to work with 997TT you will need to run a standalone. Not sure why either would want a stock ecu if you'll be pushing her above 1000Hp any way!
This is roughly 50% off retail and no down time. I'm open to offers but be realistic. Thanks
310JAY is offline
Old 09-23-2016, 04:47 PM
310JAY
310JAY's Avatar
As requested a few more pictures of custom ESmotor intake
310JAY is offline
Old 09-24-2016, 09:19 AM
OK5IMON
OK5IMON's Avatar
Also got a standard 996 Turbo engine available also if anyone also thanks
OK5IMON is offline
Old 09-24-2016, 12:06 PM
310JAY
310JAY's Avatar
Also also I have 996tt and 997tt standard engine available what's your point? Create your own thread. Good luck!
310JAY is offline
Old 09-28-2016, 11:42 PM
310JAY
310JAY's Avatar
Originally Posted by lowflying
Hi, I can attest to this built, known Neil for years, this is the best of the best, this is one hell of a deal, GLWS!!!!!
Honestly I couldn't agree with you more regarding Neil. I've been in the Porsche scene for over 15 years and never met someone willing to explain every detail of a complex build as he does, his knowledge is really unparalleled.
He actually engineer's parts for some of the fastestes porsches in the world!
310JAY is offline
Old 10-05-2016, 02:44 AM
Phoenix*
4th Gear
Phoenix*'s Avatar
@310JAY
I'm STRONGLY interested in buying this motor from you!
Could you please send me a PM, as soon as you are online, so we can start the necessary arrangements.
Thank you.
Phoenix* is offline
Old 10-05-2016, 04:06 AM
310JAY
310JAY's Avatar
Thanks for offer fellas, but not looking for any trades+cash. You can always sell your motors yourself to recoup some funds.
310JAY is offline
Old 10-05-2016, 04:08 AM
310JAY
310JAY's Avatar
Thanks for offer fellas, but not looking for any trades+cash. You can always sell your motors yourself to recoup some funds.[/QUOTE]
Whoa! That has to be the best 1st post of all time. I did pm you back as well.
310JAY is offline
Old 10-20-2016, 03:27 AM
310JAY
310JAY's Avatar
SOLD and going to a great home!
310JAY is offline
Quick Reply: Custom 4L 996/997TT engine by Performance Development
