Parts Search
Keyword:
Category:
Price (no $ sign please):
Private or Vendor Listing:
Location (Region):
Item Condition:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Cont. Porsche Models:
Color:
Private or Dealer Listing:
Location (Region):
Transmission Type:
2001 3.6L engine
Old 07-24-2018, 02:03 PM
Byprodriver
Byprodriver's Avatar
Default 2001 3.6L engine
Category: Engine - Complete
Price (no $ sign please): $15000
Part fits (select ONLY those which apply): 986, 996
Location (Region): SoCAl
Item Condition: Brand New
Some of the parts used, JE pistons & rings, heads by Costa Mesa R&D, balanced by RevCo
2001 rebuilt with LN 3.6L sleeves
Byprodriver is offline
Old 07-24-2018, 02:11 PM
chsu74
chsu74's Avatar
Nice motor. Can it run off the 3.4L stock ECU?
chsu74 is offline
Old 07-24-2018, 04:04 PM
Byprodriver
Yes no DME changes required.
Old 07-25-2018, 10:37 AM
Charles Navarro
Charles Navarro's Avatar
Received 1,077 Likes on 561 Posts
This should be a good engine for someone. Bill took our hands-on classes in GA and used the best of everything in this build. His price is quite fair considering that includes the core engine he started with in that price!
Charles Navarro is offline
Old 07-25-2018, 05:49 PM
Byprodriver
Thanks for the vouch Charles.
Old 07-26-2018, 11:21 AM
kon5t
kon5t's Avatar
Hey there, any chance you could list the parts that went into the build?
kon5t is offline
Old 07-26-2018, 11:42 AM
Coopduc
Coopduc's Avatar
Curious why you’re selling it.
Coopduc is offline
Old 07-26-2018, 03:11 PM
Byprodriver
I built it to sell right after I rebuilt the engine in my car. 5 years ago no one could comprehend what it cost to improve a M96 engine. People are starting to realize if you just upgrade the weak points these cars are as enjoyable to drive as anything you can buy.
So I believe I can sell it for what it's worth now.
Old 07-26-2018, 03:30 PM
Byprodriver
Most of them are in the 1st picture: LN Engineering 99mm billet cylinder sleeves with JE pistons & rings, LN Triple Row IMSB, ARP rod bolts. New timing chains , guides & IMS chain paddle, cleaned & tested Vario-cam, Clean & tested lifters, replaced any questionable lifters. Heads rebuilt & reinforced to prevent cracks by Costa Mesa R &D. Engine balanced by Revco in Long Beach. All Parts Ultrasonic cleaned before assembly.
Balance marks on rods
Old 07-26-2018, 08:31 PM
Brian in Tucson
Brian in Tucson's Avatar
Yup, its worth it.
Brian in Tucson is offline
Old 08-03-2018, 09:13 PM
mikefocke
mikefocke's Avatar
Triple row LN IMS bearing? I've heard of their single, dual, dual for single and flat bearing Solution. What have I missed?
mikefocke is offline
Old 08-04-2018, 09:17 AM
Charles Navarro
That was something we offered years ago, preceded by the quad row. These were offered before the advent of the IMS Retrofit and we did in-house.
We phased the triple row out when we released the Single Row Pro, back about 4-5 years ago.
Old 08-04-2018, 07:55 PM
GVA-SFO
GVA-SFO's Avatar
..Makes a lot of envy !
I currently have the OEM 3.2 in my (2001) car, with Double Row Pro, new water pump (metal impeller !!), low temp thermostat, under drive pulley, (new serpentine), 1/2 quart sump extension, full metal "x51 type" oil baffle, all of that less than 3k miles, ..but the core has 65k miles !
(The only engine mod that could have add "1 or 2" hp is the IPD intake, with large throttle box, large intake tube (IPD) and performance filter.)
OK, in my last 3k miles, half of these are good (s)miles, i.e.: Laguna Seca ones !
I think, it would have been a 3.8, I may have "cracked for" !
And reading from Mr. Raby that now we can go to 4.0, it really makes me dreaming in this direction !
(I can also say that "preparing the landing" of a good engine, I have already Bilstein PSS9, adjustable lower arms (good negative camber), front Brembo big brake kit (with 6 pistons calipers), and, my "standard" tires are NT01.
Yes, I'm really looking for more "displacement" !
GVA-SFO is offline
Old 08-04-2018, 09:33 PM
Byprodriver
You can sell your engine for about $10,000 & buy mine to have a 3.6L. It will give you 40 ft. lbs more torque thru most of the rev range to come out of corners faster. I had to get a torque bias diff to be able to use the extra torque in my car.
Old 08-04-2018, 09:42 PM
GVA-SFO
GVA-SFO's Avatar
Well, ..shall I think about a trade in ?
(15-10=5)
GVA-SFO is offline
Quick Reply: 2001 3.6L engine
