Mark this thread as Unsold
Parts Search
Keyword:
Category:
Price (no $ sign please):
Private or Vendor Listing:
Location (Region):
Item Condition:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Cont. Porsche Models:
Color:
Private or Dealer Listing:
Location (Region):
Transmission Type:
2002 Boxster S 3.2 longblock Engine
Old 08-12-2018, 03:06 PM
AZ986S
AZ986S's Avatar
Default 2002 Boxster S 3.2 longblock Engine
Category: Engine - Complete
Price (no $ sign please): $1500
Part fits (select ONLY those which apply): 986
Location (Region): West
Item Condition: Used
2002 Boxster S 3.2 L Engine for Sale
Engine S/N M96/2167210999
Miles when pulled: 81,328
Engine is a partially disassembled complete stock longblock with all accessories and parts, including a set of stock exhaust manifolds. It does have the LNE Dual row pro ceramic IMS bearing upgrade. The engine was very well maintained (exhaustive maintenance log can be provided).
I considered a DIY engine rebuild, but I don’t have the skills, patience or tools, so I’m putting it up for sale.
History
Car was a California car purchased in 2016 form a PCA member with 72,000 miles.
I did the IMS Bearing retrofit to LN Engineering dual row single ceramic.
LN Engineering pro kit. # IMSR21106, 75,000 mi warranty.
Car was used as weekend driver, 3 autocrosses and 10 HPDE events prior to engine failure.
Symptoms
Engine was running fine with no noise or lopping at idle other than low oil pressure at idle when hot issue. Tried various oil weights and finally dropped sump plate to find metal debris in the sump.
Performed a leakdown test before head removal:
Passenger (bank 1)
1 - 10%
2 - 5%
3 - 8%
Driver (bank 2)
4 - 2%
5 - 33% (leaking from intake valve)
6 - 10%Decided to take heads off to inspect and decide of a future path.
I documented the teardown and removal of the heads with many photos, and a few are posted here, the rest can be emailed upon request.
Preliminary inspection
Bank 1 (cyl 1-3) looked very good and clean. No damage whatsoever.
Bank 2 (cyl 4-6) - found broken valve keeper near cyl 5 in head under valve cover. Valve spring broken in two, and that hydraulic lifter stem was broken, 1 intake valve was bent, but was able to pull it out of guide. The cam lobe for that intake valve has a small scuff. Nothing was broken inside cylinder.
Other observed damage
# 5 piston - some visual evidence of valve impact with piston.
One small scuff in cyl 5 wall bottom. I cannot detect anything running my finger over it.
Bank 2 scavenge oil pump had evidence and damage of debris being ingested. Pump requires effort to turn by hand.
Main oil pump gears are damaged from keeper debris ingested.
Oil pump cassette wall has some scoring where debris was dragged on oil pump.
The engine was using a full filtration filter (NAPA1042), I cut it open and found very few small magnetic particles consistent with the metallic valve keeper debris. Also found minimal sparkling particles suspended in remaining oil, appeared magnetic, consistent with smaller valve keeper debris, no bearing material.
Available
Engine
2002 3.2 longblock as described above and in photos (81,328 miles). Heads, cams, valve covers, lifters, oil pump cassette, accessories, intake, plenum, throttle body, most everything has been removed. Includes wiring harness, no ECU, no clutch. $1,500
Stock manifolds/cats (Left and Right) $275
Stock secondary cats (Left and Right) $275
68 mm throttle body (stock) $60
Shifter (6 speed boxster) $100
Before disassembly
Current state
Disassembled parts
Dammage to the oil pump cassette. Was running full flow filtration.
6 speed 986 Shifter
AZ986S is offline
Old 08-20-2018, 07:00 PM
AZ986S
AZ986S's Avatar
Price drop for the engine $1,500
AZ986S is offline
Quick Reply: 2002 Boxster S 3.2 longblock Engine
