Parts Search
Keyword:
Category:
Price (no $ sign please):
Private or Vendor Listing:
Location (Region):
Item Condition:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Cont. Porsche Models:
Color:
Private or Dealer Listing:
Location (Region):
Transmission Type:
Infinity Basslink
Old 07-18-2011, 01:22 AM
ali4
ali4's Avatar
Default Infinity Basslink
Category: Audio/Video/Electronics
Price (no $ sign please): $150
Location (Region): NorthEast
Item Condition: Used
For Sale is a Infinity Basslink Subwoofer for only $150 obo, new this costs around 300. This is great for a Porsche because it looks class and elegant unline a subwoofer with a box, it takes up a lot less space and provides nice sound in smaller cars.
FROM Infinity:
You crave high-performance bass, but you don't want to use all of your available cargo space to get it. The master designers at Infinity put the same state-of-the-art technology that distinguishes Infinity speakers into the BassLink amplified subwoofer, so although it takes up just one cubic foot of trunk space, it'll produce resounding bass in any vehicle.
The BassLink brings together a 10" subwoofer, a 10" passive radiator (to increase efficiency and limit distortion), and an extremely efficient, specially designed 200-watt Class D amplifier that work as an integrated system. Special circuitry monitors voice coil position to maintain linearity at high power levels, so you hear loud, clear bass.
An array of controls will enable you to tweak your bass until it has just the thump you want. For optimum system blending, the low-pass filter is variable between 50-120 Hz (12 dB per octave), and a phase switch (0- or 180-degrees) is included. Adjust low bass impact with the bass EQ feature (-6 dB to +3 dB at 40 Hz). And you'll be able to put BassLink in a variety of in-vehicle locations, thanks to brackets that enable the rigid polymer box to be mounted vertically or horizontally. A wired remote with 16-foot cable allows you to adjust your Basslink's volume from your dash.
Details:
10" woofer and 10" passive radiator
Class D 200-watt amplifier
wired volume control with 16-foot cable
frequency response 20-120 Hz
low-pass crossover variable from 50-120 Hz at 12 dB per octave
speaker and line-level inputs
phase switch
bass boost adjusts from -6 dB to +3 dB at 40 Hz
20-amp fuse
auto turn-on with speaker-level inputs
remote turn-on lead (12V) required for use with RCA inputs
19' speaker-level input wires with plug-in harness included
14-1/2"W x 13-3/8"H x 9-7/8"D (vertical mount); 14-1/2"W x 9-1/2"H x 15-3/16"D (horizontal mount)
ali4 is offline
Quick Reply: Infinity Basslink
