Stoptech Trophy BBK 986/986/996
Category: Brakes
Price (no $ sign please): $1700
Part fits (select ONLY those which apply): 986, 987, 996
Location (Region): Midwestern
Item Condition: Used
SOLD!
Stoptech ST-60 Front Big Brake Kit. 6 Piston, 350mm floating rotors, braided steel lines, stoptech race pads and a brand new set of Carbotech Race Pads. This kit runs over $4,000 new, will take $1600.
Does this fit 987?
Yes
How used are the rotors? Do you know the part number? I'm showing for a 987.2 the stoptech kit has 355mm, want to make sure I'm looking at the right item to make sure it fits.
It's the Stoptech 83.788.6700 kit. The entire kit was purchased new in Sept of 2016 and has 8 track days on it. The Stoptech pads have about 50% life left so the rotor rings probably have 75% life. Also included is a new set of Carbotec XP10 pads.
They came off of a '99 C2 996.
Stock C2 uprights. The kit has the mounting brackets to adapt the 6 piston caliper to the upright and allow for the 355mm rotors. 986/987/996 all have interchangeable calipers.
FYI, Rich did verify with Stoptech that the calipers will not work on a 996TT.
