Parts Search
Keyword:
Category:
Price (no $ sign please):
Private or Vendor Listing:
Location (Region):
Item Condition:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Cont. Porsche Models:
Color:
Private or Dealer Listing:
Location (Region):
Transmission Type:
993 parts
Old 04-26-2017, 07:25 PM
JJK78
JJK78's Avatar
Default 993 parts
Category: Accessories
Price (no $ sign please): $100
Part fits (select ONLY those which apply): 993
Location (Region): SouthEast
Item Condition: Used
Hey everyone,
New parts added, prices lowered - Pictures available for all parts. Prices do not include shipping or Paypal fees. Need to clear out the basement! All parts removed from a 1995 911 convertible.
993 Part out Part Name Part #’s Part Description/Condition Price
#1 993 Front Trunk Latch 964.511.052.00 $25.00
#2 993 Rear Spoiler Lift Motor 964.624.111.00 Tested good working condition $80.00
#3 993 Rear Decklid Engine Light $10.00
#4 993 Rear Decklid Latch 965.512.052.01 $40.00
#5 993 Rear Spoiler Transmission Cover 964.612.225.00 $15.00
#6 993 Rear Decklid/Spoiler Wiring Harness $40.00
#7 993 Rear Decklid Spoiler & Third Brake Light 993.504.181.00 $200.00
#8 993 Front L&R wheel hubs 993.341.657.05, 993.341.658.05 Good condition, as Pictured with sway bar links, ABS sensors. $250 Each
#9 993 Steering coupler & bolt $40.00
#10 993 F&R Shock Assemblies Complete, as Pictured. Shocks, springs, mounts. $250.00
#13 993 Front Suspension Cross Member 993.341.101.05 $75.00
#14 993 F&R Sway Bar Set $100.00
#15 993 Tie Rods L&R 993.347.031.03 $50.00
#16 993 Rear suspension cross member 993.331.201.01 $150.00
#17 993 Rear suspension cross member - small 993.331.171.02 $100.00
#18 993 Rear passenger control arm 993.331.147.02 $50.00
#19 993 Rear passenger control arm 993.331.143.02 $50.00
#20 993 Rear passenger control arm 993.331.145.03 $50.00
#21 993 Right rear suspension side section 993.331.152.01 $200.00
#22 993 Rear Suspension cross member 993.331.131.04 $75.00
#23 993 Turn Signal Switch, Cruise Control 993.613.353.00 $75.00
#24 993 Headlight Switch 993.613.531.00 $20.00
#25 993 Clock Switch 993.613.325.01 $20.00
#26 993 Wiper Speed Switch 964.618.147.00 $20.00
#27 993 Dimmer switch 964.618.104.00 $20.00
#28 993 Warning Time Relay 928.618.102.03 $20.00
#29 993 Brightness Control Relay 964.618.103.00 12v 60w $20.00
#30 993 L & R Tail Lights with Bulb Sockets - Core~ 993.631.413.00 CORE condition at best. has sockets $50.00
#31 993 L & R Front Turn Signals 993.631.072.00 $60.00
#32 993 Glove box door 964.552.125.04 Black, good condition, all hinges and hook in tact. $75.00
#33 993 Glove box with light 964.552.501.03 $40.00
#34 993 Ashtray - complete 964.552.923.00 Black leatherette with housing and insert $40.00
#35 993 Dashboard hardware, brackets, covers 964.552.465.00, 964.552.466.00 Misc. mounting brackets, end covers and hardware, see pictures. $25.00
#36 993 Steering Wheel Column Housing Surround Trim with Rubber Inserts 993.552.275.00 Plastic & rubber trim pieces that surround the steering column, complete & good condition $25.00
#37 993 Heater Mixture Control Units 993.572.167.00 As Pictured with heater hoses, $150 each $100 each
#38 993 Windshield/Headlight Washer Bottle & Pumps 993.528.175.01 $50.00
#39 993 Front Trunk Hood Hinges 993.511.031.00 $100.00
#40 993 Spoiler Control Module 964.618.212.00 Tested working $150.00
#41 993 L & R Fog Light set - CORE $50.00
#42 993 2-Tone Horn Set $50.00
#43 993 Clutch, Pressure Plate and Flywheel $300.00
#44 993 Manual Transmission Pedal Cluster Includes Clutch Master Cylinder $250.00
#45 993 Clutch Slave Cylinder & hose $50.00
#46 993 Manual transmission shifter & shift rod setup $150.00
#47 993 Manual transmission starter motor $100.00
#48 993 External Oil Thermostat Assy $150.00
#49 993 Drive Shafts L&R $200.00
#50 993 Oil Tank w/ level sender $150.00
#51 993 Oil Cooler & Fan assembly $200.00
#52 993 Clutch release fork & shaft setup $100.00
#53 993 A/C Blower motor assembly $200.00
#54 993 A/C Compressor $100.00
#55 993 A/C condenser & fan assembly $200.00
#56 993 Brake Master Cylinder with Vacuum Reservoir and mount Master cylinder just replaced with new unit $300.00
#57 993 ABS pump $200.00
#58 993 Front Body Wiring Harness Front trunk wiring harness including lighting & ABS connections to fuse box. As Pictured. $200.00
#59 993 Main Wiring Harness, Gauges, Body 993.612.012.01 Main harness that runs under the dash board with connections for gauges & switches. As Pictured. $300.00
#60 993 Fuse panel & cover 993.610.011.00 Main Fuse Panel including all relays, fuses and Lid. with housing as Pictured. $150.00
#61 993 Rear Bumper Support Brackets 993.505.641.03 L&R, 4 pieces total - good condition, as pictured. $150.00
#62 993/964 Spare wheel with Vredstein tire & hold down 965.352.130.00 $125.00
#63 993 Steering Wheel - Black 993.347.804.52 Good shape, had a cover over it so mainly in good condition but some discoloring where it was not covered. $SOLD
#64 993 Drivers steering wheel airbag 993.347.089.00 Original airbag as pictured $SOLD
#65 993 Rear Bumper Cover Heat Shields 993.505.471.00, 993.505.475.00 Heat shields which go between heater pipes on motor and the rear bumper $150.00
#66 993 Wheel Lock Set w/ Key Removed from 993, 4 wheel lug locks with key. $SOLD
#67 993 Interior Light Potentiometer 964.618.104.00 $20.00
#68 993 Windshield Wiper Potentiometer 964.618.147.00 $20.00
#69 993 Blower Motor Driver Climate Control 964.624.010.02 $100.00
#70 993 Convertible Top Motors 911.624.117.00 $150.00
#71 993 Front Bumper Guards 993.505.358.00 Good condition, see pictures $75.00
#72 993 Rear Bumper Guards 993.505.425.00 OK - small cracks, see pictures $50.00
#73 993 Engine Mounts 964.375.049.00 $75.00
#74 993 Hood & Decklid Shocks with Hardware 993.511.331.00 As pictured including mounting hardware $40.00
#75 993 Passenger Airbag Dashboard cover 993.552.088.00 $150.00
#76 993 Rear Bumper Wiring Harness 993.612.045. $50.00
#77 993 Seat Bolts $20.00
#78 Misc Porsche Wheel Lock Parts $20.00
JJK78 is offline
Old 04-26-2017, 07:27 PM
JJK78
JJK78's Avatar
#79 993 Convertible Intermediate Roof Bow 993.561.029.00 70B Complete with Side levers and protective covers, Bungees in good shape $200.00
#80 993 Convertible Steering Arms - Right 993.561.070.00 70B NLA? $250.00
#81 993 Convertible Steering Arms - Left 993.561.069.00 70B $250.00
#82 993 Convertible Roof Frame 993.561.027.00 70B Straight, 1 captured nut broken loose $150.00
#83 993 Convertible Roof Frame Seal 993.561.189.00 Good condition, 2 small tears $75.00
#84 993 Convertible Roof Seal Guide Rails 993.561.325.00 $50.00
#85 993 Convertible Padded Roof Locks Cover 993.561.197.00 70B $100.00
#86 993 Convertible Roof Wiring Harness & Microswitches $50.00
#87 993 Convertible Rear Clamp & sealing strip 993.561.063.00 70B $150.00
#88 993 Convertible Rear Supports 993.561.379.00 $40.00
#89 993 Convertible Top Lock Cover 993.561.295.00 70B $50.00
#90 993 Convertible Guide Pins 911.561.449.65 “retaining pivot, locating peg” $35.00
#91 993 Convertible Rain Channel 993.561.301.00 70K $30.00
#92 993 Convertible Frame Bolt Assortment 911.561.420.00 8 Total $50.00
#93 993 Convertible Miscellaneous Hardware $25.00
***THE FOLLOWING ITEMS ARE AVAILABLE FOR LOCAL PICKUP ONLY - NO SHIPPING***
#94 993 Drivers side rear suspension with Hub 993.331.151.01 Drivers side complete as Pictured. $500.00
#95 993 Drivers Door with Windows 993.531.005.02 Includes windows & window motor & wiring harness as pictured. No Mirror, No Handle, No Interior Panel. Not original paint. $350.00
#96 993 Passenger Door with Windows 993.531.006.02 Includes windows & window motor & wiring harness as pictured. No Mirror, No Handle, No Interior Panel. Not original paint. $350.00
#97 993 Lower dash board - black 964.552.076.06 Black vinal, everything functioning $150.00
#98 993 Fuel Tank System Fuel tank with filler neck and accompanying bits including carbon canister (sounds broken inside). As Pictured $150.00
#99 993 Power Steering Lines & Reservoir Engine compartment to steering rack lines & reservoir. As Pictured. $100.00
#100 993 Convertible Main Roof Bow 993.561.015.02 70B Repaired but in good working condition - removed from perfectly working top $400.00
#101 993 Body Oil lines from T-Stat to Cooler NO SHIPPING $200.00
#102 993 L&R Side Rockers Panels 993.559.519.00 Good condition. $100.00
#103 993 Front Drivers Seat - Needs recovering Good condition but cover need to be replaced, motors & electrics work good, as pictured. $200.00
#104 993 Front Passenger Seat In good useable condition $300.00
#105 964/993 Mismatched Wheel Set, CORE ROLLERS, Chrome, Three 964 wheels and one front 993 wheel all need refinishing. Tires 50/50, Michelin Pilot Sports but rear are dry rotted. $200.00
#106 993 Drivers Front Fender Good condition, not original paint, paint OK but not great. $200.00
#107 993 Front Bumper Reinforcement w/ Bumper Shocks 993.505.011.00 Good condition, as pictured. $200.00
#108 993 Front Bumper Cover 993.505.311.20 Some wear & tear, seen a few speed bumps and parking lot curbs, not original paint. $250.00
#109 993 Rear Bumper Cover 993.505.411.00 Good condition, looks like it may have had a low speed rear impact. $250.00
#110 993 Rear Bumper Reinforcement w/ Bumper Shocks 993.505.021.03 Good condition, as pictured. $200.00
JJK78 is offline
Old 04-26-2017, 10:32 PM
hexagone
hexagone's Avatar
Sent PM about seats.
hexagone is offline
Old 04-26-2017, 10:41 PM
JJK78
JJK78's Avatar
Front control arms sold! Thanks!
#11 993 Drivers Side Control arm - Sold
#12 993 Passenger Side Control Arm - Sold
JJK78 is offline
Achtung964
Achtung964's Avatar
You have a PM.
Achtung964 is offline
Old 04-27-2017, 10:09 AM
JJK78
JJK78's Avatar
All PMs replied to!
THANKS!
J
JJK78 is offline
Old 04-27-2017, 04:43 PM
JJK78
JJK78's Avatar
#63, #64 & #66 - Steering wheel with airbag and wheel lock set now SOLD
THANKS!
J
JJK78 is offline
Old 04-29-2017, 11:45 PM
JJK78
JJK78's Avatar
Photos of decklid wiring harness for Bob "Downunder"
Thanks!
J
JJK78 is offline
Old 05-02-2017, 12:06 AM
BahnBurner
BahnBurner's Avatar
Could you post a photo of #15?
BahnBurner is offline
Old 05-02-2017, 01:10 AM
_snowbird_
_snowbird_'s Avatar
Interested in #57 ABS pump. Will send a PM.
_snowbird_ is offline
Old 06-07-2017, 01:54 PM
genesyn
5th Gear
genesyn's Avatar
Interested in #41 (L and R foglight set) if still available. Is it $50 for the set or $50 each? Have pictures?
Never bought anything through rennlist before so not sure how the process works.
Gene
genesyn is offline
Old 06-07-2017, 04:11 PM
mgianzero
mgianzero's Avatar
Do you have any of the bezels for the switches in center console?
Marc
mgianzero is offline
Quick Reply: 993 parts
