(4) 18" 7.5" and 9" HOLLOW SPOKE Twists with Tires
1 Post
Category: Wheels & Tires
Price (no $ sign please): $700
Part fits (select ONLY those which apply): 911, 924/931/944/951/968, 928, 964, 986, 987, 993, 996
Location (Region): SoCAl
Item Condition: Used
Fronts: Part No. 993.362.134.05
Rears: Part No. 993.362.138.00
was $1,200.00 obo now blow out at $700
Some light scuffing and scratching on original finish (see pics). Includes center caps and tires. These wheels (hollow spokes) cost a small fortune new... Buy used and save big. Not willing to split up the set. Local pick-up in Los Angeles, CA is encouraged; however, shipping to any US state is available. I will charge for UPS Ground at $220.00 for all wheels.
Fronts: Part No. 993.362.134.05 18”x7.5” Offset = 50mm; Weight = 8.6kg; Tire Size = 225/40/18, roughly 8/32 tread Continental.
- Compare to solid spoke twists at 11.3kg. The hollow spoke wheels weigh 3.3kg less, or 7.3lbs less!/ Per wheel.
Rears: Part No. 993.362.138.00 18”x9” Offset = 52mm; Weight = 10.2kg; Tire Size 265/35/18, roughly 8/32 tread on Continental.
- Compare to solid spoke twist wheels at 13.2kg. The hollow spokes wheels weigh 3kg less, or 7lbs less!/ Per wheel.
